Everything Enyaq
  • #236802
    Southamman
    Viewing 25 replies - 1,276 through 1,300 (of 2,330 total)
    • #279390
      bolly1143
        Just curious how people are finding the heaters in the car, I have to turn up to 27+ to get any heat, I know early cars had issue with this and the car wouldn’t open all the flaps due to software bug.
        After having the car in garage for 10 weeks with previous issue I don’t fancy waiting again for another fix.
        On our other EV’s heat has been instant and really warm, but it’s really poor in our Enyaq.
        Cheers 🙂
        #279392
        Dee49
          @bolly1143 the seat. Mine has easy access feature. Not sure if they all have it. When you get in, close door and car is on your profile and you put your foot on the brake the seat is meant to go to your preset seat position. Mine does this around 50% of the time. Other times it doesn’t move at all and I have to hold and press no 1 on the seat or it moves a bit and I think I’ve got shorter until I realise that the seat has only moved half way !!!
          I also tried the one press with the door open. It didn’t work. Had to hold it down for it to move.
          #279393
            Mine is weird, when I got in in January the heating was left on 16 as the car was warm enough, you could feel the heat, now it’s warming up outside (in theory) I’m having to put it up to at least 20 to even feel it.
            #279395
            bolly1143
              @bolly1143 the seat. Mine has easy access feature. Not sure if they all have it. When you get in, close door and car is on your profile and you put your foot on the brake the seat is meant to go to your preset seat position. Mine does this around 50% of the time. Other times it doesn’t move at all and I have to hold and press no 1 on the seat or it moves a bit and I think I’ve got shorter until I realise that the seat has only moved half way !!! I also tried the one press with the door open. It didn’t work. Had to hold it down for it to move.
              I’ve the easy access also, just checked and mine needs single press with door open, but needs long press door shut, not sure if it’s right/wrong or software related.
              Seems the luck of the draw, not had much use from the car so I’m sure it’ll change it’s mind as time goes by.
              Hope you get it resolved as it can become frustrating.
              #279397
                I’ve the easy access also, just checked and mine needs single press with door open, but needs long press door shut, not sure if it’s right/wrong or software related. Seems the luck of the draw, not had much use from the car so I’m sure it’ll change it’s mind as time goes by. Hope you get it resolved as it can become frustrating.
                Every car Ive had with easy access seat, works on IGN when the car is turned on/off. Once the memory seat position was set, you never needed to touch the memory button again unless a change of driver on memory 2.
                This has been the case with a Skoda Superb, Kodiaq, BMW’s and Hyundai.
                • This reply was modified 1 year, 4 months ago by kezo.
                #279401
                Dee49
                  Kezo you are right. It is activated by the IGN. In the Enyaq sitting in the seat and putting your foot on the brake puts the car into ready mode. This means you don’t need to touch the ignition button. I’ve tried it both ways to make sure but it didn’t make any difference to the seat movement.
                  #279488
                  thekopfather
                    Hi, we are thinking of putting an order in for an Enyaq on Monday and was just asking this question do you regret ordering one and would you order one again in the future? Thank you
                    #279490
                      Yes and no really!, I ordered an 80x and got the 85x in January.
                      Dealer experience was very poor, lied about the price of the paint I preferred (Velvet Red) told me it was full price £1045 when it should have only been the difference between it and the standard metallic, so £385.
                      Also lied about the quality of the Canton sound system, paid the extra £2035 for the Advanced pack and it’s mediocre at best, sub-woofer is barely noticeable.  Apart from the HUD and Matrix headlights the rest of the pack isn’t needed, heated windscreen, heated rear seats (just use the cars pre-heat function) and Crystal grille.
                      If I could go back and re-order I’d have an 85 Edition instead.
                      Would I buy one again?, I really don’t know, the Winter range is a massive drop of around 100 miles (so 1/3 of the battery capacity).  There’s constant reports of software issues (mine has came up with the “Don’t Drive!! Overheated Battery” warning twice so far and the charge flap was sticking even on the day I picked it up!.  The Skoda App and servers are pretty bad but that’s common across all the VW group MEB3/4 range.
                      So, looking ahead to 2027, would I have another BEV? certainly, without a doubt.  Would it be another Skoda or other VW group car? I really don’t know, I’ll certainly be keeping an eye on the competition 🙂
                      #279499
                        I’m really hoping that something comes onto the scheme soon that will persuade me to cancel mine.
                        #279502
                        Avatar photoSolymar
                          I think if the Hyundai EV6 GT came on I would be very tempted. There’s loads of new stock around too so would be quick delivery!
                          I’m surprised Motability Operations don’t look at stock cars in the current manufacturing delay climate, I’m sure it would please a lot of people if stock cars which are ready available were allowed on the scheme to help fulfil the backlog of orders! 🤔 If only temporarily!
                          #279503
                          Kjid5
                            I think if the Hyundai EV6 GT came on I would be very tempted. There’s loads of new stock around too so would be quick delivery! I’m surprised Motability Operations don’t look at stock cars in the current manufacturing delay climate, I’m sure it would please a lot of people if stock cars which are ready available were allowed on the scheme to help fulfil the backlog of orders! 🤔 If only temporarily!
                            my ID5 was a stock car ?
                            #279504
                              Thats very much up to the dealer, as they have purchased the car from the manufacturer out of their own personal £’s for their showroom/forecourt, in the hope a retail customer comes in and buys it at or near “retail” price.
                              Motability deals directly with the manufacturer where the dealer acts as a third party to place a factory order with the manufacturer on behalf of Motablity.
                              However it is very much up to the dealer whether they will let you or I as a Motability customer have one of their vehicles from stock.
                              #279520
                              Dee49
                                @thekopfather your questions are good ones. Do I regret ordering an Enyaq. I’m on the fence with that one but I’m swaying to a yes. Cars software is just so full of bugs- reminds me when Windows 95 came out !!  Just today I had another error. Yellow warning triangle with an exclamation mark and a beep. Looked everywhere to see what the error was. It was only when I selected reverse that I noticed that the front sensors weren’t working. Stopped car. Got out locked it, unlocked and error gone!
                                would I get another one? That would be a no. I’m not put off with an electric car so would go for another one just not from the vw group. Toyota cars were always reliable for me- had 4 and the only time they were in the garage was to get serviced. So maybe an electric Toyota if it gets good reviews.
                                #279522
                                Nas89
                                  My week old id4 had both these errors and went into limp mode! Luckily over night it cleared… But might get it checked out as dont want to be stranded far from home
                                  #279523
                                  Nas89
                                    bogzaf
                                      I have a question off topic – how long have you all been waiting from day when your car were build to collection ? Skoda says anything between 2 to 4 weeks but I was wondering what’s your experience? My car is set to be build in next 9 days which is confirmed and no change expected
                                      #279541
                                        I had all of this stuff with the MG fix was when it didn’t reset by on and off a 10mm spanner disconnect the 12v battery fixed it, I always thought it was a China SAIC thing but guess it’s just any of them.
                                        Imho it’s not just the software as much as the stupid communication protocol canbus is crap and was not designed to be as complicated as it is now there’s no redundancy to it, it’s not particularly robust and more
                                        All car co’s have their problems in Toyota who are recalling 1m vehicles due to potentially faulty airbags and 380,000 in the US with faulty brakes and another 280,000 again in the US that may creep forward in neutral due to a software fault.
                                        Ford and VW have the wet belt engine destruction business on their 3 cylinder engines going on there’s just do much bad engineering going on in the car industry.
                                        #279627
                                        thekopfather
                                          Hi, thank you for answering my previous question, just one more quick one I’m not sure to order the 21 inch or stick to the 20 inch wheels? Could I ask is there much difference between them in ride quality and if anyone knows and thank you 😊
                                          #279628
                                          thekopfather
                                            Hi and thank you for your reply.
                                            #279647
                                            Avatar photoSolymar
                                              I test drove the Enyaq Coupe with 21″ wheels and to be honest, the ride was un-faultable. There was minimal road noise from the tyres & the suspension handled the pot holes & speed humps brilliantly.
                                              I think the diameter of the 21″ wheel with tyre is 29″. My Mercedes has 18″ wheels and measures 26″ so, the same amount of rubber on the ground. I’ve not seen any official figures that show the larger wheel affecting range.
                                              #279756
                                                Just heard my 85x order from December is now built and on it’s way to the docks as of Friday 7th so estimates are another 2 weeks… Yay
                                                #281529
                                                bogzaf
                                                  do you think 2 weeks is realistic? I’ve asked question on Škoda Enyaq fb page and people said from build to actual get a car was something between 6 to 8 weeks. It was very rear below 4 weeks. My car is due to be build on Monday so I am just wondering how long this will take.
                                                  #281531
                                                    Just relaying what I was told.
                                                    #281573
                                                    jamiemc88
                                                      From build completion to me taking delivery mines was about 10 days, fastest manufacturer to do so for me over the years, was very impressed. Although if they had waited an extra day and gave it a good detailed clean I wouldn’t have minded!
                                                      #281592
                                                      bogzaf
                                                        I see. So it really depends then I guess from dealer shipping etc. I will have to wait another week to find out how long my dealer think it will take.
