Preparing for an EV- advice on charger
  • #164684
    Psuader
      I am pretty sure that my next Motability car will be an EV. I’m really excited by the prospect but have a concern. What if I order one, get all excited and at the last hurdle the charger can’t be installed for one reason or another relating to the wiring at my property?
      Is it possible to get an assessment done now on my existing electrics to avoid all that fuss, by the nominated suppliers of EV chargers? I think its BP?
      I believe BP are falling behind in terms of time taken to install chargers for orders delivered, so that may not be an option.
      I wonder if a rival might at least do a no obligation assessment?
      What do you think?
    • #164685
        there was a video going about on motability re this i think..  sure there will be some threads on here too.
        #164687
        Ldc7080
          I can’t speak for Hyundai but Kia and VW Evs are in a 5-6 month lead time.  I think BP will be able to sort you out in such a time frame
          #164688
            There are any number of independent companies fitting EV charging points who will do a survey and quote for the work, Psuader.  You may have to send them pictures of your meter and charger locations.  They will let you know if you are likely to face any difficulty.  Obviously you’re not under any obligation to go ahead with them.
            #164689
            Psuader
              Thanks Wigwam!
              #164690
              Jacippit
                I put up a post yesterday with some helpful tips etc (admin maybe make this sticky?) when it comes to electricity supply etc.
                Motability will only provide a free charger if you park within your property boundary, otherwise they give you a BP Pulse card which can get you free but slow public charging.
                If you are going to have to purchase a charger after much research you will be hard-pressed to beat the Hypervolt Home 2.0.  Installers love them and the customer service and feedback looks top draw. I’m looking at £1100 supplied and fitted but if I get favourable electricity rates I can recover this in just over a year by the cost difference compared to diesel (10k miles).
                #164695
                kbfern
                  I wonder if it’s possible to get the £350 Gov grant off that £1100 it would soften the blow a bit.
                  OLEV Grants
                  #164698
                  Jacippit
                    No grant for us as parking space not within our boundary line.
                    #164702
                    Intranicity
                      otherwise they give you a BP Pulse card which can get you free but slow public charging..
                      Incorrect.  If you can’t have a charger installed you get a 3 year free subscription to BP Pulse, but you still have to pay for your electric usage.
                      Previous Motability Cars
                      #164703
                      Ian
                        Also remember you can charge wiyh a 3 pin plug albeit a little slower…..
                        #164704
                        Jacippit
                          See below taken from BP Pulse website – free charging.
                          Free charging at selected points.
                          pulse
                          #164706
                          Intranicity
                            Yes, just as you get free charging at Tescos. but there are hardly any “Free” BP Pulse chargers, but there are plenty of “Free” chargers out there that are not BP Pulse.
                            The 3 year subscription gives you reduced rate charging.
                            Slow 7kW 16p kW compared to 26p
                            Fast (Upto 50kW) 23p kW compared to 35p
                            Ultra (100kW plus) 42p regardless of subscription.
                            PS I have the Free Subscription so know how it works, but rarely use it as I have better offers through Hyundai
                            #164726
                            Psuader
                              Thanks all so far. My issue is that the ones I’ve approached keep asking for ME to do the assessment, taking pictures of fuse boards etc. I want them to do the assessment!
                              #164728
                                Any reason not to take the pictures? They can decide from the pictures what’s need the same as being there. They don’t do any testing.
                                #164742
                                  interestingly i decided to open the wooden casing where my dno fuse is. it used to be looped but was changed a good few years ago.  anyway i got a pic but there is no markings on it to see.  my tails are 12.5 mm re my micrometer tho.
                                  im guessing fuse is probably 60 but no way of knowing.
                                  im guessing its probably wise im not getting an electric now although i wanted a kona ultimate tbh but was told it would be a long time.dno
