Ohme Home Pro help please
  • #290390
    Collie
      So I thought I would get my app up and running before my car arrives at the end of the week and i am confused. My app screen shows
      Load limit 100A
      CT clamp reading 1A
      Load balancing on
      Max charge current 32A
      My issue is with the CT clamp reading. It stays at 1 amp even when I put the kettle on, but I have noticed that on the screen of the charger it changes from 1 amp to about 10. Is this normal or is my clamp on the wrong way or something.
    • #290393
      Ioniq
        @collie
        You will only see a CT clamp reading when you are charging your car.
        The CT clamp is for the charger only, also, to tell the smart meter when you are charging.
        #290403
          The CT clamp monitors the total household load (not just that of the charger) and will reduce power to the charger, should your total useage be within 10-15% of the incoming supply fuse rating.
          The app should mirror that of the charger but, if the charger is showing 10A, I wouldn’t worry about it untill you have your car. However, if you have a 13A kettle, the charger is reading slightly low but, again I wouldn’t worry at this stage.
          #290424
          Collie
            Thanks. I’ll wait and see when the car comes then. Probably me just worrying too much.
