- This topic has 20 replies, 7 voices, and was last updated 3 years, 7 months ago by
Brydo.
- August 17, 2022 at 11:55 am#194455
Most of us are feeling the pinch with inflation hitting 10%+ and fuel bills hitting catastrophic levels so i thought it would be a good idea to share some of our money saving tips.
I thought i would post a link to https://www.moneysavingexpert.com Martin Lewis money saving advice as he’s a pro but here are some of my own.
1. Freeze your loaf on purchase day and just take out what you need when you need it.
2. Half your dishwasher tablet as that’s all you need and it will do a similar job.
3. When using your oven try and cook as many meals as possible at the same time.
4. Do you put loads of cold water in your bath after running the hot? turn your water heat level down on your boiler. Do this a bit at a time until you achieve a temperature that suits you and have a bath with the wife/husband, or, at the very least use the same bath water.
5. Turn your washing machine temp down to 30 degrees, and use the quick wash for most clothes, only using a longer cycle for soiled garments.
Lets hear your tips, if you have any.
Anything i post over three lines long please assume it is an article lol. - CreatorTopic
- August 17, 2022 at 12:01 pm #194458
Don’t fill the kettle.
August 17, 2022 at 4:13 pm #194481don’t buy anything. eat less. use microwave meals instead of oven meals. if you have an old freezer, buy a new one. if you rarely use your freezer, switch it off. switch off microwave at wall when not in use(surprising how much power it uses on standby). use modern led lights. use money saved to buy whisky. be happy..
Last Car: Toyota C-HR Excel Hybrid...4 way 80kg hoistAugust 17, 2022 at 8:05 pm #194523If you have kids / grandkids, Asda are feeding kids for £1 in their cafe till the 4th September, no need for adults to buy a meal and no minimum spend, just £1 kids meals!
Enyaq EV
August 17, 2022 at 8:22 pm #194524
ajnThat’s great Jojoe, thanks for the info, most of the Asda stores near me have closed their cafes, turned them onto McDs and such like, even Sainsbury closed theirs recently too, now just a storage area… Shame great latte’s..
Great deal for the parents though if you have the asda cafe up and running..
August 17, 2022 at 8:22 pm #194525
BrydoThanks for that one joejo ?
August 18, 2022 at 7:02 am #194549
ajnOther way brdyo ?, Jojoe, I kept getting the jo & joes mixed up too..
August 18, 2022 at 12:54 pm #194601Gas Boiler energy saving
https://www.energy-stats.uk/low-temperature-heating/
August 18, 2022 at 1:58 pm #194621I understand a lot about heating systems having designed and installed my own the the past. I would absolutely recommend anyone who doesn’t to read this article. It is excellent. Thanks for posting it Oscarmax.
August 18, 2022 at 2:06 pm #194623<p style=”text-align: left;”>In fairly lucky in that my house is fairly thermally warm.</p>
There is tons of insulation in loft. The cavity walls have recently been redone, and have fairly modern double glazing.The central heating is relatively young at about 9 yes. Combi Boiler has never given any issues. Doors are ok too
Last Car: Toyota C-HR Excel Hybrid...4 way 80kg hoistAugust 22, 2022 at 4:46 am #194935
AnonymousMost of us are feeling the pinch with inflation hitting 10%+ and fuel bills hitting catastrophic levels so i thought it would be a good idea to share some of our money saving tips. I thought i would post a link to https://www.moneysavingexpert.com Martin Lewis money saving advice as he’s a pro but here are some of my own. 1. Freeze your loaf on purchase day and just take out what you need when you need it. 2. Half your dishwasher tablet as that’s all you need and it will do a similar job. 3. When using your oven try and cook as many meals as possible at the same time. 4. Do you put loads of cold water in your bath after running the hot? turn your water heat level down on your boiler. Do this a bit at a time until you achieve a temperature that suits you and have a bath with the wife/husband, or, at the very least use the same bath water. 5. Turn your washing machine temp down to 30 degrees, and use the quick wash for most clothes, only using a longer cycle for soiled garments. Lets hear your tips, if you have any.
This is great tips, and some of them was really helpful for me some time ago. Also I had a I also had a table where I entered all my income, expenses, debts and that showed me the real amount of money which I had
August 22, 2022 at 8:15 am #194942Low powered fan near your radiator they will distribute and circulate the warm air around the rooms rather than back out the window ?
August 22, 2022 at 10:34 am #194952Adding to @Oscarmax useful link above. I also think Delta T 60, 50…… is an important factrften overlooked.
Rather than trying to explan about it, I found this on Stelrad that’s easy to understand
https://www.stelrad.com/news-events/blog/the-importance-of-delta-t-in-calculating-heating-output/
I use the zapper if making 1 or 2 cuppa’s for me and the wife. I also cook alot of meat, meals in a slowcooker to cut down on oven use.
August 23, 2022 at 1:39 pm #195079Adding to @Oscarmax useful link above. I also think Delta T 60, 50…… is an important factrften overlooked. Rather than trying to explan about it, I found this on Stelrad that’s easy to understand https://www.stelrad.com/news-events/blog/the-importance-of-delta-t-in-calculating-heating-output/ I use the zapper if making 1 or 2 cuppa’s for me and the wife. I also cook alot of meat, meals in a slowcooker to cut down on oven use.
I have Stelrads fitted all round, we are going to remove the top covers and remove the dust, or should I say the wife will.
August 23, 2022 at 1:40 pm #195081Get an Iceland discount card it is free, also 10% off on Tuesdays for the over 60’s
August 26, 2022 at 11:03 am #195230
JojoeI switched off the extractor fan in the bathroom. It was on a pull cord and we’d leave it on for 30 minutes or so after a shower. We have double glazing which allows you to fully lock the window whilst it’s slightly open to vent the room. I’ve read extractor fans use quite a bit of electric.
August 26, 2022 at 11:41 am #195235
DanteI use small solar lights instead of maims lights – I put them on the window sills during the day ti charge and then around the house ti light things up by motion at night time lol – mad but it works. Boiler at lowest temperature / eco mode when used .
fast daily wash in low temp for my clothes – works perfectly well
August 26, 2022 at 12:39 pm #195239I switched off the extractor fan in the bathroom. It was on a pull cord and we’d leave it on for 30 minutes or so after a shower. We have double glazing which allows you to fully lock the window whilst it’s slightly open to vent the room. I’ve read extractor fans use quite a bit of electric.
I’m a spark and fitted an exhaust fan on the exterior (only a vent cover inside) a couple of years ago. It clears the bathroom in no time especially on high. I think it cost around £75 trade (£110 retail)
A ventaxia 4″ silent extractor fan uses 3.2w on low and 5w on high. Where as a centrifugal fan uses 19w. 1Kw of electricity is equal to 1000watts. Taking the centrifugal fan uses 19w it would have to be on for 52hrs to consume 1Kw of electricty 1000/19. On the otherhand a cooling fan can use around 40w (1000/40=25hrs runtime to consume 1Kw of electricity.
My advice is to run your bathroom fan during and after a shower for 20 – 30mins and then allow any condensation left to tricke out the window. You do not want to run the risk of condensation build up which can seap through plasterboard ceilings or bath room cabinets over time or run the risk of a mould problem especially in winter, that could prove more costly in the long run. Oh and ignore over exaggerated scaremongering articals in the media.
What bathrom fan do you have?
You can calculate most appliances by the same formula 1000/x watts. An electric oven or kettle will be in Kw, so for example a 3Kw kettle will say take 5mins to boil. you would have to boil it 12 times before it used 3Kw/h of electricity. 3Kw/h of electricity say =3 x 55p (Kw/h price)=£1.65 now divide that by 12, it costs £0.1375p each time you boil the kettle. ?
August 26, 2022 at 1:23 pm #195242@kezo It’s a 4 inch fan, the walls are fully tiled. I’m happy to vent via the window in warmer months. I’ll use the fan in the depths of winter.
Enyaq EV
August 26, 2022 at 1:26 pm #195244Save more and don’t use shower. Wash at sink . Hey my gran and grandad did it all their lives as they had no bathroom, and were perfectly clean. He was a dispensing chemist in Aberdeen.
Last Car: Toyota C-HR Excel Hybrid...4 way 80kg hoistAugust 26, 2022 at 1:27 pm #195241
BrydoIn the morning Wash your face with cold water, seemingly it’s good for your skin lol.
My son has started taking cold showers, nothing to do with saving money he follows some guy who swears by them. Seemingly it is very good for you in a number of different ways.
