Nissan Ariya
  • #298958
    Jason23
      So I picked up my Nissan Ariya 87k Evolve today in Aurora Green and first impressions are excellent. The car has everything you could possibly think of or at least I can think of.
      It is lovely to drive and really comfortable. Taking it for a proper ride on Saturday so I will report back on how that goes.
      • This topic was modified 7 months ago by Jason23.
    Viewing 25 replies - 1 through 25 (of 35 total)
    • #298959
        @Jason23 how about a few pics for the viewer’s.
        #298962
        Jason23
          I will take a few in the morning and post.
          #298966
            Nice – looking foward to the pic’s 🙂
            #298973
            Matty M
              It was in the running for us, until MB removed the AWD options, which halved the towing capacity down to 750kg.
              If the AWD comes back before mid-May, we will consider it – but I can’t imagine it will win out against the IONIQ 5.
              #298982
              Jason23
                Try again….
                #298983
                Jason23
                  Jason23
                    Jason23
                        Looking good. Nice car, enjoy.
                        #298995
                          It was in the running for us, until MB removed the AWD options, which halved the towing capacity down to 750kg. If the AWD comes back before mid-May, we will consider it – but I can’t imagine it will win out against the IONIQ 5.
                          Unfortunately with Nissan current problems this may not happen, we are in a similar position we tow a 1500kg caravan, the current PHEV AP very steep.
                          #299020
                          Jason23
                            I made a mistake when I got the Ohme Pro Charger installed. I thought that 5m of cable would be plenty but it is not. I have had to park the car quite close to the front door, much to the wife’s annoyance as that was the only way the charging cable would reach.
                            I messaged Ohme about it and they said I would be looking at over £300 to getthe cable changed to 8m so I was wondering if there was anyone who has had need of an extension cable for their Ohme charger so I can park the car on the drive in it’s normal spot?
                            Fortunately I will not have to charge it too often in the meantime.
                            #299024
                              I made a mistake when I got the Ohme Pro Charger installed. I thought that 5m of cable would be plenty but it is not. I have had to park the car quite close to the front door, much to the wife’s annoyance as that was the only way the charging cable would reach. I messaged Ohme about it and they said I would be looking at over £300 to getthe cable changed to 8m so I was wondering if there was anyone who has had need of an extension cable for their Ohme charger so I can park the car on the drive in it’s normal spot? Fortunately I will not have to charge it too often in the meantime.
                              EV cable shop unfortunately £99.
                              You can get a local electrician to change your tethered cable, I had mine change from a type 1 to type 2, took him less then half hour.
                              #299025
                                Jason23
                                  EV cable shop unfortunately £99. You can get a local electrician to change your tethered cable, I had mine change from a type 1 to type 2, took him less then half hour.
                                  Thank you.
                                  #299027
                                  Jason23
                                      I think my next car might be black, that looks great.
                                      #299041
                                      Jason23
                                        It is actually green that also looks black or purple under different lighting.
                                        #299045
                                        Avatar photoELTel
                                          EV cable shop
                                          The extension posted is only rated to 16a and a max of 3.6kw. They don’t seem to have any of the 32a or 7.2kw in the 5m cables, they are sold out.
                                          https://www.evcableshop.co.uk/search?q=Type+2+to+Type+2+-+EV+Extension+Cable&type=product
                                          EX30 SMER Ultra
                                          #299046
                                            EV cable shop
                                            The extension posted is only rated to 16a and a max of 3.6kw. They don’t seem to have any of the 32a or 7.2kw in the 5m cables, they are sold out. https://www.evcableshop.co.uk/search?q=Type+2+to+Type+2+-+EV+Extension+Cable&type=product
                                            There was a drop down menu where you could select 16A or 32A and 10m 32A was £99 when I initially posted, I had highlighted the 32A!
                                            #299098
                                            Jason23
                                              I don’t know if I should buy a new cable (circa £120 for 10m) and get a local sparky to change it over or to buy the extension cable (well wait for it to come back in stock first) and just use that?
                                              #299103
                                              Jason23
                                                My local sparky asked me to contact Ohme to see if the cable could be replaced. Naturally they said no as it would invalidate the warranty. Their price to change is £96 plus a call out charge of £198 so £294 in total.
                                                Either that or I just continue to park the car by the front door overnight whilst it charges.
                                                #299105
                                                  The beauty of an extension cable (whils’t  no the be all and end all), is it won’t invalidate the chargers warranty and will get you out of a fix relatively cheaply however, I would stick with a maximum 5m extension.
                                                  #299106
                                                  Jason23
                                                    Would this be suitable please? Also thanks for your help.
                                                    RamTouch EV Charger Extension Cable (32 Amp, 7.4 kW, 5 m, 1 Phase), Type 2 Extension Cable Compatible with all Type 2 EV Chargers & Type 2 Wallbox, EV Extension Cord Suitable for Type 2 EVs/PHEVs : Amazon.co.uk: Automotive
                                                    • This reply was modified 7 months ago by Jason23.
                                                    #299108
                                                    Jason23
                                                      Ohme have told me that trying to change the cable would invalidate the warranty.
                                                      #299110
                                                        Would this be suitable please? Also thanks for your help. RamTouch EV Charger Extension Cable (32 Amp, 7.4 kW, 5 m, 1 Phase), Type 2 Extension Cable Compatible with all Type 2 EV Chargers & Type 2 Wallbox, EV Extension Cord Suitable for Type 2 EVs/PHEVs : Amazon.co.uk: Automotive
                                                        There is no mention of ip rating, I can see which I would be dubious of, especially as an extension cable., unless you can come up with a solution of covering the connection when it rains, such as a weatherproof box?
                                                        Using amalgamating tape could be a longterm solution, if you kept both cables connected!
                                                        • This reply was modified 7 months ago by kezo.
