HA Asking for more documents
  • #256358
      @kezo
      Just received an email from my HA regarding the charger install requesting more documentation.
      We now have a full list of what is needed from the customer post installation of an EVC:
      Electrical Installation Certification (EIC) includes NICEIC/NAPIT electrical installation of full works โ€“ you have provided thank you
      Would you be able to provide the following please
      EV charge point installation certificate along with make and model + clear photo of installation
      Certification of Part P Building Control โ€“ Ohme have advised this should have been sent out to you
      Evidence from the District Network Operator (DNO) โ€“ due to GDPR Ohme has said they cannot provide this and would need to come from the tenant – DNO (Northern power grid) gave approval on the 18th Dec, the approval reference is ENQ23160563.
      Documentation on manufacturers warranties if received
      I don’t have any of the above, and no idea what they want from the DNO?
    • #256359
        These are the only documents I’ve received, all have been passed on to the HA
        Pro EV – EV Installation RAMS.docx
        Electrical Certificate ZAP-D7BC9F042D (Jeffrey Davison)-1.pdf
        EVHS Installer Authorisation Letter – ProEV.pdf
        From DNO – AOE – no works required – small works.pdf
        Napit Cert.pdf
        ProEV Insurance Certificate 2023-2024.pdf
        WCS Installer Authorisation Letter – ProEV.pdf
        #256385
          The Napit EIC should cover the charger installation (a) new circuit (b) consmer unit.
          Part P certificateย  can take up to 30days to arrive, from when the installer notified your LA’s building control dept. (You can check on the LA’s online planning portal to se if it has been registered yet)
          Send DNO ref: ENQ23160563, if by email forward to the HA or just a note with ref number on
          Was there anything in the box that stated charger warranty? I will see if I can find a warranty cert if not.
          Was Jeffrey Davison the installer?
          #256388
            @kezo
            It’s me ๐Ÿ™‚
            I’ve emailed the DNO saying my HA has asked for the following,
            Evidence from the District Network Operator (DNO) โ€“ due to GDPR Ohme has said they cannot provide this and would need to come from the tenant โ€“ DNO (Northern power grid) gave approval on the 18th Dec, the approval reference is ENQ23160563.
            Only thing in the box was the instruction booklet. I assumed the warranty would be given to Motability as they paid for it.
            #256392
              Print/email this out and give to HA
              • This reply was modified 2 years, 2 months ago by kezo.
              #256395
                If the HA already know the DNO approval referance, I don’t know what else they could want!
                You could forward the DNO email that has the referance number on it.
                They really haven’t got a clue mate and Ohme want shooting for not sending all the documents to the property owner.
                #256405
                  Agreed ๐Ÿ™‚
                  The Ohme document and a copy of the DNO email outlining the work plus me telling them I’ve asked the DNO to pass on whatever it is they have seems to have done the trick, well most of it!.
                  She’s going to contact me in a month to see if I have the Part P, who will that come from, Pro Ev ?
                  And once again, thank you very much for all your help ๐Ÿ™‚
                  Hopefully this will be the end of it!
                  Just waiting for Octopus to update my billing and see what I was actually charged for charging the car.
                  #256410
                    Sheโ€™s going to contact me in a month to see if I have the Part P, who will that come from, Pro Ev ?
                    The registered electrician or ProEV will notify the work with you loacal authority’s building control dept, who should send out a Part P cert. It can take 30days before you receive this.
                    You can also check on you LA’s planning portal to see if it registered
                    #256415
                      And once again, thank you very much for all your help Hopefully this will be the end of it!
                      Your welcome mate anytime ๐Ÿ™‚
                      I’d like to think this will be the end of the matter, so you can get on with life. Shame I didn’t live closser but, hey ho we got there in the end ๐Ÿ™‚
