Air Fryer
  • #294063
      I’ve only gone and done it.
      Thanks to George and Black Friday I’m the proud owner of a £45 air fryer.
      9 litre capacity, independent cooking zones with removable divider. 5 star reviews.
      Exciting times. All cooking and recipe tips welcome.
    • #294072
        Congrats! I use youtube for various recipes 🙂
        #294073
        Ioniq
          Use it for everything.
          I never use the oven since getting one.
          I guess only use the oven one day a year and thats Christmas.
          #294074
            Baked potatoes 🥔 are perfect in the air fryer. Wash and dry them, prick with a fork rub oil into them with salt and pepper. About 50 minutes on 200c. I’ve found homemade chips are best if you cut them very thick, par boil for 3 mins, dry them, oil them, pre heat for 3 mins to 200c and cook for 20 mins ish, very similar for roast potatoes except I shake the pan hard after par boiling for 5 mins to roughen the edges to make them crispy.
            #294075
              @wmcforum Better late than never, welcome to the world of air fryers. We have the Ninja and a top tip is to save grease we use these. https://www.amazon.co.uk/dp/B0BMXF1W2Q?ref=ppx_yo2ov_dt_b_fed_asin_title
              #294077
                Regular sausages – 180c for 15mins!
                • This reply was modified 10 months, 2 weeks ago by DumfriesDik.
                #294082
                Avatar photoWillis
                  We bought the Ninja 15 in 1 about 14 months ago and whilst I was a little worried that it would become an expensive cupboard ornament, (We paid about £250) I am so glad my wife talked me into it.
                  We use it for so much, including cooking large joints on the steam roast function for melt in your mouth meat, par boiling roasties on the pressure function for 2 minutes and perfect results, fantastic bread, using both the prove and steam bread functions and amazing crackling covered pork joints using the roast function and temperature probe. It is also brilliant for all of the normal air fried stuff. So quick and so cheap in comparison to the normal oven.
                  #294117
                    We bought the Ninja 15 in 1 about 14 months ago and whilst I was a little worried that it would become an expensive cupboard ornament, (We paid about £250) I am so glad my wife talked me into it. We use it for so much, including cooking large joints on the steam roast function for melt in your mouth meat, par boiling roasties on the pressure function for 2 minutes and perfect results, fantastic bread, using both the prove and steam bread functions and amazing crackling covered pork joints using the roast function and temperature probe. It is also brilliant for all of the normal air fried stuff. So quick and so cheap in comparison to the normal oven.
                    We have the 7 in 1 Ninja, I’ve not roasted a chicken since we got it. I slow cook with 250 ml of chicken stock. Sit chicken on sliced carrots and onions, salt n pepper on top add stock set to high and cook for 5 hours, lovely moist chicken. Even did a turkey in it last Christmas.
                    #294138
                    Ele
                      Yet again the Mrs gets what she wants
                      Our kitchen is better equipped than Nando’s
                      The rubber mats underneath is to enable them when in use to be easily pulled forward with a tug of the mat ensuring they are kept well away from the rear power cable,as it gets quite hot back there
                      • This reply was modified 10 months, 2 weeks ago by Ele.
                      #294148
                      mitch
                        blimey @Ele how many do you feed, you could run a take away with those.
                        #294155
                          Do you bother brown for the last 15-20min on air fry setting?
                          #294157
                            @kezo, I do sometimes but I try not to eat the skin, even though it’s lovely when crispy, there’s  too much fat.
                            #294161
                            Ele
                              Not airfryer related but we always cook beef in our slow cooker
                              Cook on Max 4.5/5hrs cut a few carrots  in big chunks place in the bottom sit joint on top
                              No liquid required
                              Leave alone,once cooked /cool/place in fridge overnight then ready to slice
                              If needing it hot place slices into a oven tray cover with heated gravy place in preheated oven then serve
                              The best/moist/tasty beef ever,every time,same cooking method with a leg of lamb maybe less cooking time than the beef depending how you like it,ours 3.5/4hrs
                              #294163
                                Not airfryer related but we always cook beef in our slow cooker Cook on Max 4.5/5hrs cut a few carrots in big chunks place in the bottom sit joint on top No liquid required Leave alone,once cooked /cool/place in fridge overnight then ready to slice If needing it hot place slices into a oven tray cover with heated gravy place in preheated oven then serve The best/moist/tasty beef ever,every time,same cooking method with a leg of lamb maybe less cooking time than the beef depending how you like it,ours 3.5/4hrs
                                I tried a silverside joint in the slow cooker but it was really dry, I think it would have been best totally covered with stock rather than an inch at the bottom.
                                #294167
                                Ele
                                  We Dont do that no need our method works perfect every time
                                  Our slow cooker is a simple Asda 6 ltr cheapy with simple high low settings (use high)
                                  I suspect its the cut as we only use the cheaper roasting joint
                                  Give that ago you will be amazed how well it cooks
                                  #294169
                                    We Dont do that no need our method works perfect every time Our slow cooker is a simple Asda 6 ltr cheapy with simple high low settings (use high) I suspect its the cut as we only use the cheaper roasting joint Give that ago you will be amazed how well it cooks
                                    Started cooking beef joints (brisket etc) in slow cooker every since I tasted my mum/dad’s slow cooked meat a long time ago. I either do on bed, as Ele, with no fluid or put just under half a can  of stout or red wine in and which ever method always comes out juicy and suculent.
                                    #294181
                                      Richmond signature sausages on offer Tesco £2 20 mins from chilled in air fryer they are lovely shake half way
                                      #294237
                                      Ele
                                        Double posted this please Admin delete other
                                        https://www.hotukdeals.com/deals/half-price-ps6-per-kilo-4472231
                                        #294236
                                        Ele
                                          Slow cooker high setting
                                          HEADS UP
                                          #294239
                                            Scampi 15 mins 200c wonderful
