- This topic has 5 replies, 3 voices, and was last updated 6 years, 6 months ago by .
Article
The full report of the Zap-Map EV Charging Survey published today (Monday 21st October) reveals new trends in EV charging behaviour in the UK based on the experience of Zap-Map’s own survey panel.
Looking at the findings from one area of the report – the changes in behaviour on the public charging network – some clear trends are emerging.
• Electric Vehicle (EV) users demanding more powerful chargers on UK public network
• 4% annual increase in proportion of EV drivers using rapid units as network grows by 43%
• Increase in charging duration on rapids with more users charging for 40+ minutes
In 2019, 85% of EV drivers report using fast (7-22 kW) and 86% non-Tesla rapid chargers (>43 kW), the two most popular units. This is a 13% increase as compared to 2016 and represents an average annual increase of 4% in the proportion of EV drivers using both fast and rapid units.
These trends partly reflect the increased availability of both fast and rapid chargers on the UK network, the numbers of which have grown by 27% and 43% respectively in the past 12 months.
However, given that the proportion of EV drivers using the public charging network is broadly stable (currently at 94%) as is the usage of slow units (<3 kW), the figures also suggest an increasing demand from EV drivers for more powerful chargers on public network.
This growing demand is supported by other data from the survey which reveals an increase in charging duration on rapid units over the four years to 2019; with 16% more users reported to be charging for 40 minutes or more and 18% fewer charging in under 40 minutes.
The increase in charging time on rapids – which is highly significant, representing an 146% increase from a low base in 2016 (>40 minutes) – is likely to be due to the higher battery capacities used by newer EV models and also to the increasing use of EVs for longer journeys.
To add to these trends, EV drivers may also be charging more often as the survey finds that users report arriving at public charging points with a higher state-of-charge (SoC) than before. Between 2016 and 2018, the surveys reveal a 6% reduction in users reporting SoC 0-20% on arrival together with a 6% increase in users with SoC 20%-40%.
This change may be due to the relatively large numbers of new EV users in the UK market who tend to be more risk-averse than experienced drivers. Or it may reflect changes in journey type from local to motorway journeys where running low on charge is a particularly critical issue due to the limited number of charging locations along strategic routes.
Commenting on the launch of the report, Dr Ben Lane, CTO at Zap-Map, noted: “Zap-Map’s EV Charging Survey published today provides unique insights into the charging behaviours of EV drivers across the UK – at home, at work and on the public network.
“In a market which is doubling every two years, quality information is an essential commodity with which to track and monitor emergent trends. Our objective with the annual EV Charging Survey is to provide just such data to accelerate the EV market in the UK and beyond.”
