- This topic has 20 replies, 13 voices, and was last updated 1 year, 3 months ago by
Johno21.
- December 2, 2023 at 1:23 pm#250637
How do stop or prevent the screen wash from freezing in an EV, which has no engine heat? I guess you could use a concentrated winter solution, just curious.
- December 2, 2023 at 1:33 pm #250640
You would think after this amount of time car manufacturers would have a heated/warmed tank!, my Ateca has heated washer nozzles, great idea but totally useless when the tank or tubes are frozen 🙁
December 2, 2023 at 1:43 pm #250642So far the coldest I’ve got into the Kona EV is -3 and I’ve never had that problem.
I just use a screen wash from B&M.
December 2, 2023 at 1:50 pm #250644i had a kona for three years and recently an ioniq 5. this has not happened to either. i use regular supermarket diluted screen wash.
Cheers, all the very best
Vaun
December 2, 2023 at 2:10 pm #250646I use Halfords concentrated -20 screenwash, about a£10 for 5l, which lasts for some years.
December 2, 2023 at 2:16 pm #250647I use Halfords concentrated -20 screenwash, about a£10 for 5l, which lasts for some years.
+1
December 2, 2023 at 2:24 pm #250650Tme to drain and refill with better screen wash I think!
But then again, I don’t go out if it’s snowed or is icy (cr@p tyres) and the Enyaq is (hopefully) coming in January so probably not worth bothering 🙂
Actually found a car with worse tyres/traction than mine!, my friend took me out in his Jaguar E-Pace yesterday, even with his “Snow” setting he couldn’t get more than half way into my little estate never mind the small bank up to my corner cul-de-sac!, had to drop me off and I walked the rest of the way, very carefully indeed!. Even my Ateca is better than that!.
December 2, 2023 at 5:31 pm #250664I use Halfords concentrated -20 screenwash, about a£10 for 5l, which lasts for some years.
+1 from me too. It’s good stuff.
I do miss electric screen defrosting though. (down to the chip shortage when I got my Pug 308 GT Premium.)
Coming soon...BMW X2 sDrive 20i M Sport 5dr Step Auto In November 2025December 2, 2023 at 5:45 pm #250666Our vehicle has heated windscreen wipers, not a heated windscreen, because we use a Halfords screen cover too date not had to use it.
December 2, 2023 at 5:48 pm #250668Well Pug does have heated wipers and screen wash. But the frost has been severe, so still need to use deicer. I keep meaning to get one of the screen covers. I will look on line in the morning.
Coming soon...BMW X2 sDrive 20i M Sport 5dr Step Auto In November 2025December 2, 2023 at 7:41 pm #250674@joss you can’t beat a windscreen cover, especially if going out early morning before the winter sun is high enough. Better than a credit card or scraper.
December 2, 2023 at 11:09 pm #250685-5 and snow here this morning when I set off for shopping, the EV is no different to a normal car, except Kia OEM wipers go hard as rocks at just under zero and it heats up much quicker inc. fast windscreen defrost, no need to scrape the screen unless you are in a real hurry.
I am using Prestone -10 screenwash, same as my ice diesel, good to about -6 or 7…failed miserably at -9 last winter.
December 3, 2023 at 9:37 am #250695@joss you can’t beat a windscreen cover, especially if going out early morning before the winter sun is high enough. Better than a credit card or scraper.
Going to get one this morning@Kezo
Coming soon...BMW X2 sDrive 20i M Sport 5dr Step Auto In November 2025December 3, 2023 at 10:50 am #250700Along similar line, the screenwash on my C5x ran out with no warning. Posted on a C5x forum and apparently no sensor fitted and this is now quite a common practice. If it is I think it’s ridiculous as running out can be bl00dy dangerous.
Anyone else had this?
December 3, 2023 at 11:04 am #250701Along similar line, the screenwash on my C5x ran out with no warning. Posted on a C5x forum and apparently no sensor fitted and this is now quite a common practice. If it is I think it’s ridiculous as running out can be bl00dy dangerous. Anyone else had this?
Yes it’s the same on my Pug 308 GT Premium. No washer level indicator. Which for a top of the range car is bloody annoying to say the least.
Coming soon...BMW X2 sDrive 20i M Sport 5dr Step Auto In November 2025December 3, 2023 at 11:18 am #250703I regularly check my screen wash especially in this weather, I always carry some spare fluid in the boot just in case.
December 3, 2023 at 11:22 am #250706<p style=”text-align: left;”>
</p>
I do now Oscarmax ?December 3, 2023 at 12:17 pm #250715@joss you can’t beat a windscreen cover, especially if going out early morning before the winter sun is high enough. Better than a credit card or scraper.
Even better press the phone app and car screen is defrosted and inside as warm as set temp in 10 mins no need to be plugged in to do so
No need to warm the engine up first in an EV
Car keeps on giving
December 3, 2023 at 12:39 pm #250721A preheated cabin and a windscreen cover are no use if the screenwash is frozen in the bottle, in the pipes and in the nozzles ??
And while an ICE will produce excess heat that was only really effective when the screenwash was mounted on the bulkhead, nowadays they’re all near the very front on the engine bay or under the wing… furthest point from the hot exhaust and most exposed to the cold.
No warning light is annoying but if you’ve got a rear wiper it’ll run out of fluid first so it gives you a little warning to top up
December 4, 2023 at 5:10 am #250770I like Prestones screen wash, and at the moment use it diluted 50/50. It seems to be holding.
And slightly off topic, I use Rain-X to clean all windows and mirrors externally.
June 30, 2024 at 2:29 pm #283449I use Halfords concentrated -20 screenwash, about a£10 for 5l, which lasts for some years.
Yeah that’s the right 👍.. it’s got to be waterless ready to use
