- This topic has 40 replies, 5 voices, and was last updated 4 years, 1 month ago by
kezo.
- March 12, 2022 at 4:00 pm#179917
I replaced my kitchen wall units, all of which had hard wired under cabinet 240V lights. I replaced all of my units except one, I now have a light and cable sticking out the wall. My wife wants to put a shelf with fairy lights or something similar all of which require a transformer. All of the lights I’ve seen have the transformer and plug combined. How do I link the fairy lights to this circuit so when the cabinet lights come on the new fairy lights come on at the same time on the same circuit?
Anything i post over three lines long please assume it is an article lol. - CreatorTopic
- March 12, 2022 at 7:50 pm #179929
Best advice I can give you is invest in a spark. Play safe with leccy
Last Car: Toyota C-HR Excel Hybrid...4 way 80kg hoistMarch 14, 2022 at 8:49 pm #180087It should be quite easy to do, can you post a link or picture of what you intend buying, you can buy separate transformers usually called LED Drivers.
You can cut the plug off the fairy lights and connect the lights direct to the driver, but you must choose the correct driver, if you can get a picture of the plug on the lights you intend buying the output information of the transformer should be on there.
I’m assuming the lights are connected in series and the redundant light is the last one in the circuit, having only 1 cable, do all the other lights have 2 cables? It’s not as complicated as it sounds.
Daughters motability car Hyundai Tucson Ultimate self charging hybrid Serenity White Moss Grey interior.
My car SEAT Ibiza SE Tec 1.2 petrol TSI 2017.March 15, 2022 at 12:29 pm #180103
Marc thanks for getting back to me.The light is the first one from the switch not sure about the number of cables coming in to each light.
The photo of the fairy light we already have but will be getting another the same.
Anything i post over three lines long please assume it is an article lol.March 15, 2022 at 12:30 pm #180104
Anything i post over three lines long please assume it is an article lol.March 15, 2022 at 12:30 pm #180105
Anything i post over three lines long please assume it is an article lol.March 15, 2022 at 12:31 pm #180106
Anything i post over three lines long please assume it is an article lol.March 15, 2022 at 12:32 pm #180107Ps the dimmer switch works ceiling spot lights not the cabinet lights.
Anything i post over three lines long please assume it is an article lol.March 17, 2022 at 3:08 pm #180299
Hi Brydo so you want to connect your fairy lights to the cable you are holding in your hand?
March 17, 2022 at 3:43 pm #180304Yes Kezo that’s correct ?
Anything i post over three lines long please assume it is an article lol.March 17, 2022 at 6:15 pm #180325Unwrap the tape and remove the choc blocks (remember to turn electric off or isolate the circuit) bring the cable out higher if it suits better. Fit a 13A socket onto the existing cable but write/label print 6A max onto the socket where it can’t be seen when fair lights plugged in for aesthetic reasons, as suspect it’s coming off the lighting circuit. Then plug your fairy lights into it. You could also use a drywall box to flush mount the socket.
Is this suitable or were you thinking of something else?
March 17, 2022 at 7:02 pm #180330I didn’t want to have a plug fitted, was hoping to hard wire it direct to that cable with some sort of in line transformer, if such a thing exists.
Anything i post over three lines long please assume it is an article lol.March 17, 2022 at 7:08 pm #180331Marc, above, spoke about a driver, not sure what that is.
Anything i post over three lines long please assume it is an article lol.March 17, 2022 at 7:51 pm #180332Led driver. Can you take a close up pic of you plug can’t fully see the output dc voltage
March 17, 2022 at 9:38 pm #180339There is a photo above Kezo but if it’s not clear enough let me know and I will take another?
Anything i post over three lines long please assume it is an article lol.March 17, 2022 at 11:22 pm #180348Can’t quite fully make it out, so if you can do a close up please and will see what drivers or step down transformers match the output.
March 18, 2022 at 12:23 am #180350
Anything i post over three lines long please assume it is an article lol.March 18, 2022 at 12:24 am #180351Is that any better ?
Anything i post over three lines long please assume it is an article lol.March 18, 2022 at 10:32 pm #180449Is that any better ?
Sorry for the late reply Brydo had my fibromyalgia flair up this morning.
Ok I can read it better now. So I think what would be suitable for what you want is an Led panel driver. This will give you the voltage out you require as stated on the plug 31V DC.
I have found this at a good price https://www.amazon.co.uk/LEDLUX-30V-42V-Constant-Current-60X60cm/dp/B08DYB95GR/ref=asc_df_B08DYB95GR?tag=bingshoppinga-21&linkCode=df0&hvadid=80401889848623&hvnetw=o&hvqmt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=&hvtargid=pla-4584001428411331&psc=1
Have you access to Amazon ?
March 19, 2022 at 11:30 am #180475So just cut off the transformer and connect wires to each end of the driver and we’re good to go?
Anything i post over three lines long please assume it is an article lol.March 19, 2022 at 12:00 pm #180482Exactly mate, self explanatory once you have it in front of you. Hopefully once you cut of transformer and bared wires back you should be able to decipher which one is + and – (though doubt it matters with string lights)
Any probs give me a shout.
March 19, 2022 at 12:40 pm #180486Apologies for the late reply from me also, been working away from home this week.
The driver in the link kezo posted will be suitable, we have a static caravan and we’re here now, I’ve taken some pictures, just connect the 240Vac feed to the input and the fairy lights to the output, be aware that the output is dc, on standard fairy lights it should not matter which way + or – that they are connected as kezo points out, however if the lights are LED they will have to be connected in the correct polarity, LEDs will only permit current in one direction, so after connecting it if the fairy lights don’t work then switch the output wires around and the fairy lights should work.
Below is a picture of the driver, 240Vac in 24Vdc out.
My car SEAT Ibiza SE Tec 1.2 petrol TSI 2017.March 19, 2022 at 12:46 pm #180489This is a picture of the output terminals, 24Vdc to the lights, the input , on the left hand side of the previous picture is fed via a light switch. The driver is behind the fire inside the false chimney breast with the switch on the right hand side of the breast.
My car SEAT Ibiza SE Tec 1.2 petrol TSI 2017.March 19, 2022 at 12:55 pm #180490This is a picture of the setup, there are four 24Vdc strip lights connected in parallel in the display cabinet, the driver is behind the fire and is controlled by a switch on the right hand side of the chimney breast, the output cable from the driver is fed through the cupboards below and comes out at the left hand side of the display cabinet and is run up the side of the cabinet in trunking with each strip light tapped off in parallel.
My car SEAT Ibiza SE Tec 1.2 petrol TSI 2017.March 19, 2022 at 1:14 pm #180491One of the options is to fit a pattress box, blanking plate and trunking. Screw the pattress box to the wall over the currently fitted choc block connector, attach a new cable to the chock block and run this out in trunking as an extension, you can put the driver where you want then.
Trunking
Tower PVC White Self-Adhesive Mini Trunking 16mm x 16mm x 2m | Mini Trunking Lengths | Screwfix.com
Pattress
Tower Mita 1-Gang Surface Pattress Surface Box 25mm | Back Boxes | Screwfix.com
Blanking plate
1-Gang Blanking Plate White | Blanking Plates | Screwfix.com
My car SEAT Ibiza SE Tec 1.2 petrol TSI 2017.March 19, 2022 at 1:38 pm #180494Links that hopefully work.
https://www.screwfix.com/p/lap-1-gang-blanking-plate-white/65793
https://www.screwfix.com/p/tower-mita-1-gang-surface-pattress-surface-box-25mm/33241
https://www.screwfix.com/p/tower-pvc-white-self-adhesive-mini-trunking-16mm-x-16mm-x-2m/60548
My car SEAT Ibiza SE Tec 1.2 petrol TSI 2017. - AuthorReplies
