Cost
  • #270016
    Sid
      Hello,
      Can someone help me with how much Motability takes from my 3 year lease
      I have a £75.75 total allowance
    • #270019
        Currently £71 per week
        From 6th April £75.75 per week
        #270020
        Sid
          @kezo thanks do you know the full amount of the 3 years they will take as i want to make sure i can continue with Motability as pip is my only income
          #270024
          Anonymous
            @kezo thanks do you know the full amount of the 3 years they will take as i want to make sure i can continue with motability as pip is my only income
            almost all vehicles on the motability scheme will take the full amount of the higher rate mobility component. Unless your PIP incorporates some daily living payments you would have no PIP for an income if you join the motability scheme.
            the total sacrifice in terms of PIP income vs a vehicle on the scheme would be at least £11,817 from over 3 years from next month.
            It would be best to check your award paperwork and work out what is best financially
            Good luck
            #270025
              From April Motability take £303 every for weeks and 39 payments in total over a 3 year lease £11,817 🙂
              Do take into consideration PIP rates increase each April and Motability will keep the increase each year 🙂
              #270060
              Sid
                Thank you @ScotT  @kezo for the  information and I will take into consideration
                #270197
                  Bare in mind if like myself there are two revenue streams for PIP, one, Mobility part that you give to MB for the car as mentioned above but, two, there’s also a Daily living part that will be paid direct to you if you have this part of PIP too.
