What a Faff
  • #224170
    Ele
      Hi
      I have been going around in circles on the phone for hrs this morning
      Going through the process of having a electric charger installation
      Just had a contractor do a load test and as thought further work to tails/upgrade fuse is needed
      Was told to contact my electric supplier ( British Gas ) to let them know the outcome and arrange with them to do  the work
      Here is the problem
      I have rung 3 times on British Gas dedicated contact number which as I have since found out is via ( I assume) India
      Clueless and plainly untrained to deal with my concerns
      and each time was kept on hold or hung up on
      Each time they failed to have a clue about my concerns
      Now in a catch 22 situation and right now unable to go forward with the works needed prior to installation
      Also getting mixed advice as told by instllation guys I am able to keep my PAYG Prepayment meter Load checker hinted that I may have to have a smart meter
      I want to keep my PAYG Meter as their is no advantage to having a smart meter ( having read about the problems people are having with them and seeing that my charges will soon be no more than by direct debit )
      So I will just wait and see who if anyone contacts me
      Couldnt make it up
      Has to be one of the worse customer experiences I had next to DWP/Drs/Tax office lol
      • This topic was modified 2 years, 10 months ago by Ele.
    Viewing 22 replies - 1 through 22 (of 22 total)
    • #224177
        Try contacting BG via Twitter or Facebook, they tend to put you through to the correct people.
        #224186
        Avatar photojunglegreen
          Hi @Burgerman333,
          are you sure it’s your electricity supplier that you need to contact to arrange work and not your DNO? (Distribution Network Operator)
          Sean
          Current car Hyundai Kona Ultimate EV
          #224191
            I always thought the DNO was responsible, might be worth a call if you’re getting nowhere with your supplier.
            We have a smart meter for payg and it makes paying easier,  online payment with card and it’s all done from home, no need for a trip to a shop.  I too can’t wait for the price correction.
            Ele
              Hi
              My elec bill is with British Gas who has a call centre in India
              The load check print out this morning was conducted by a firm called Haste in Petersfield ( been in touch cant help)
              They are contractors to load test by DNO Scottish and southern
              Been in touch with them and cant help as I do not have a direct account with them
              I am still in a catch 22 situation
              Looking like a granny lead at this rate
              #224187
              Berty
                I was under the impression you had to have a smart meter fitted for EV charging. The reason being
                that overnight charging is at a cheaper rate, and the supplier can only know that if the smart meter tells them when the EV charger is being used.
                Currently if you only have a Paygo meter you will be paying a higher rate for charging your EV.
                If there is no data link to your supplier, it will be rather costly.
                I’m not sure if there are new Paygo meters that can differentiate EV charging is being used??
                #224197
                  Looking in detail, your dno will change the fuse, your supplier is responsible for upgrading the tails.
                  Bulb are accepting responsibility and will get on with it.  British Gas, by contrast, put the whole process on the dno. https://www.britishgas.co.uk/energy/charge-point-dno-process.html
                    With the Standing Charges were all paying around £300 per year at moment without even using any electric so at the very least this should be free, after all, that’s what the SC is for, paying for supply chain so there happy to tell us.
                    @Burgerman333
                    I’ve been unfortunate to have been dumped with BG after my energy company went bust and I’ve also spent an hour on the phone talking to a dumb head about my Smart Meter not having the correct rates set so meaningless as the rate is set 16p per KWh but after arguing for an hour that there was nothing wrong with my SM but just needed the correct rates pushed to the meter they suddenly realised I had the SM installed in 2017 so was not covered by any guarantee. I explained again and again that there’s nothing wrong with the meter but British Gas need to push over the network the correct rates and they said, after an hour that is, I’d have to speak to their technical department. Think I’d be still on the phone now had I done that but hopefully we will be given the choice to a supplier of our choice next month when they say comparison sites might return.
                    #224205
                    Ele
                      Cheers understood and many thanks
                      {Looking in detail, your DNO will change the fuse, your supplier is responsible for upgrading the tails.]
                      You are indeed correct and this is the first time anyone has told me this
                      Ordinarily this would now be a simple process but the plan falls short simply because I have no way of communicating and addressing my concerns with my supplier B/G
                      3 drawn out attemps to resolve via India is enough for me
                      Polite people for sure but they do not have resolution training
                      Head spinning and back to 3rd phone call to my Easee charger installer
                      (They may have a solution and one for others to note)
                      Been advised by Easee as followers
                      Taking into account my energy suppliers failure to facilitate a reasonable line of communication they will contact Motorbility explain my dilema and ask if the Motorbility contingency fund ( which exists to fund/help with additional charger installation costs ) can be used to cover the cost of their installer taking on the work that B/S would need to have done.
                      Leaving it with Easee for now and see what pans out over the next week
                      Just to add reliable PAYG metre is quite the norm when installing a charger and will soon be no dearer than direct debit
                      My low mileage dosent warrant a Smart metre and off peak tariffs
                      If it aint broke
                      Thanks for the explanations as its helped no end
                      Will update asap
                      #224202
                      Berty
                        Yup Chris, its a bit of a minefield. My buddy bought a Tesla, but cannot charge from home, and he has a smart meter (SM) he was with Octupus Energy.
                        What his supplier has said is, they cannot communicate with the SM as it is a First Generation model and the SIM is not sending data to the supplier. It could be the SIM is in a dead zone and that is why it doiesnt communicate.
                        I reckon SM technology is a bit out of whack with current technology and with everyone ordering EV’s they need to make a Gen 3 SM to accomodate EV charging.
                        I moved to a SM a couple of years ago thgrough British Gas, and it is supposed to tell me in real time how much energy I am using on their Website.   It has never worked as it should.
                        I can see my energy useage in realtime on the small monitor they fitted.
                        Best guess is that British Gas does not have the infrastructure to handle the realtime data coming from the smart meters. Or just maybe they are overwhelmed by taking on new custmers after the carnage of energy suppliers going to the wall.
                        #224223
                        Ele
                          Sorted at last ( fingers crossed)
                          Like a dog with a bone I have been attacking this ALL day
                          Stage 1 of 3 supplier B/Gas doing their bit this Mon
                          Then I have to set up a DNO visit
                          Then easy part getting installer on site
                          It was only because I was given B/Gas complaints email that I was able to be listened to
                          thanks to those of you on here and also
                          Great customer care from Easee and also @wepoweryourcar
                          What a faff
                          There needs to be a better way its not the 1930s lol
                          • This reply was modified 2 years, 10 months ago by Ele.
                          #224227
                            That’s Amazing and well done for sticking with it.
                            It’s a new thing, remember while EVs have been around for a good few years, these installs have only picked up a decent pace over the last 3 or 4 years.  EV Charger installers, electricity suppliers and DNOs are still getting used to who does what and in what order it needs doing and, compared to the scale of their businesses it’s still a relatively unusual requirement.  Hopefully they’ll all get better before too long.  It doesn’t help that some suppliers are particularly awful at customer service.
                              My low mileage dosent warrant a Smart metre and off peak tariffs If it aint broke
                              This is quite a conundrum. I have done a paper exercise some time ago and like you, I didn’t think it worth going onto an EV tariff due to low mileage. However, Intelligent Octopus at 7.5p for six hours overnight and a peak rate of 30p I will have to take a serious look again.
                              Well done on getting your ducks in a row. It is just a one time faff (I hope!) and I hope plain sailing from now on.
                              #224306
                              Ele
                                Think I will delve deeper
                                Thanks for the heads up
                                #224315
                                Ele
                                  Seems a Faff that I have had to have so much trouble at stage 1
                                  just getting my landlords permission for my charger install
                                  I live in a city and was left with the impression that I was the first to seek such a thing ( there is no direct line of communication just confusion as everything is done through a 3rd party switch board
                                  Badly managed and zero excuse imo
                                  Fortunately I had previously amassed  a few contacts whilst undertaking ( during covid lock down )an 18 month quest/securing/completing ( another untold story lol ) Disabled facilities Grant application for the installation of a double brick paved driveway.
                                  Driveway has been a god send as it now allows me to be able to go forward and get a home electric charger installed
                                  My tone is not one of complaint as I am very grateful for all I have
                                  I am simply telling my tale to show some others that what may seem like a mountain can be overcome with a little tenacity
                                  My Guess is
                                  Thats something that many on here already relate too.
                                  #224330
                                  Berty
                                    Brilliant Burgerman, glad that you are now sorted.
                                    But you are breaking new ground here, and no doubt others will have similar problems with Hpme Charging and their energy supplier.  Good you got a fix under your belt.
                                    I just watched  a UK Youtuber who couldnt charge his new Megane Etech overnight on off-peak. He was using his Zappy charger and it seems the Megane is not yet compatible with the Zappy wall charger.
                                    There are a lot of other complaints on their forum and it is indeed a problem with Renault.  They need to do an update on the Megane to fix it. Apparently it can’t be done over T’Internet, but has to go into the dealers?
                                    Anyway, he also had Ohmie as he called it – a basic outlet  for outside events, and this did indeed work very well charging the Megane overnight on Off-peak.
                                    Anyway = onwards and upwards, glad all is OK..
                                    #224355
                                      Congrats!
                                      Yes, dealing with electricity suppliers is a faff, they are not really geared up for anything other than faults on the line. Especially DNO’s – although some are better than others.
                                      Its a shame really as it tarnishes the EV experience, even though it’s not the cars fault. Thankfully its a done that, no need to sort it again thing.
                                      The problem is that you suffer from dealing with 3-4 different firms all telling you different things & you don’t know who to believe. But as said, all finally sorted.
                                      As for smart meters, most low rate EV tariffs need a SMETS2 meter – the SMETS1 (first gen meters) are not capable of supplying the readings they need. Octopus will change your meter for you for free, from SMETS1 to SMETS2, others should be the same.
                                      And you don’t need a smart meter to have an EV, I didn’t get mine fitted till a year after I had the car and charger, as I wanted to move onto an EV tariff and realised I’d need one. Fitted in minutes by SSEN after one phone call and a wait of about 2 weeks. Thankfully SMETS2, as all new meters should be.
                                      #224374
                                        Octopus upgrades, as Abercol mentioned, a SMETS1 meter to a SMETS2 meter for free (or upgrades the existing one if capable). We had it done too.
                                        There’s no way around that if you want to take advantage of, for example, their Octopus Intelligent tariff. Which, for others that are interested, works well. We were a bit sceptical over letting Octopus decide “when to charge” our car, but it works a treat, and we get quite a bit of “free” (well, discounted) electricity over the daytime too.
                                        So far, the car has always been charged by the point in time that we set in the app (the way it works that through the octopus app, you tell them the desired SoC, and what time you want that SoC – and they sort out a “charging plan”, charging the car on and off whenever it’s cheapest for them. You have an off-peak time (7.5p) from 11:30 to 5:30 – we had a few situations now where they charged the car outside that window, which sets your entire account back to “off-peak” while the car is charging. So every week we have a few hours of off-peak prices in daytime. We set 100% SoC at 8am in the morning, plug the car in whenever over the course of the day, and it charges as required to get to 100% at 8am.)
                                        #224429
                                        Ele
                                          Very detailed
                                          Food for thought
                                          thanks 4 sharing
                                          #224459
                                          Blackj
                                            Had the same problem with fuse board. Scottish power are responsible for supply in Scotland. New meter heads fitted and 80amp main fuse replaced in 6 weeks after ohme visit.  Most older properties have a lower amp fuse fitted which caused my ohme charger to keep tripping. Now upgrade done no problems.
                                            #224556
                                            Richard
                                              You say that about smart meters but in order to access novel tariffs or tariffs aimed at getting cheap electricity for your EV will need a smart meter.
                                              We’ve had one about 4 years now and haven’t had a moment’s problem despite living rural coastal. We are on Octopus Agile now the price per kWh changes every 30 mins so if you can load shift and avoid heavy use between 4 and 7pm you’re laughing. Weekend just gone price on Sunday was between 5 and 1p per kWh due to low demand. We are saving on average 45% over Octopus Go (4 hours off peak electricity for charging overnight) there are also the odd times the price goes negative so you’re being paid to use power.
                                              Not knocking you staying on your current meter if that suits you go for it however certain tariffs are only young to be available on smart meters long term.
                                              My EV charger install took 7 months with numerous calls to EV charger co, DNO and electric supplier was a total nightmare but really worth it
                                              Time for new car next year really want to stay electric if possible
                                              #224664
                                              Ele
                                                Food for thought
                                                And will be taking a closer look,thanks for the detail most helpful
                                                My mileage is only 6500 a year so not to many hrs of charge
                                                I see at the moment the Octopus Intelligent tariff. rate for my area is as follows
                                                Unit rate (23:30 – 00:00):
                                                7.50p/ kWh
                                                Unit rate (05:30 – 23:30)  :41.11p/ kWh
                                                Standing Charge: 47.95p/ day
                                                Will look again on 1/07/2023
                                                • This reply was modified 2 years, 9 months ago by Ele.
                                                #227124
                                                Ele
                                                  Update getting there
                                                  stage 2/3 now completed DNO Scottish and southern fuse upgraded
                                                  DNO Fuse upgrade took less than 15 mins to install as they were able in myvparticular case able to hook over a fuse adaptor which by all accounts speeds their job up
                                                  Very quick job ( sat outside at 7.30am waiting to gat in made them wait till 8am as wasnt pre warned of this )
                                                  All in all v quick and now ready for final stage 3/3
                                                  Easee home charger install date
