- This topic has 9 replies, 5 voices, and was last updated 3 years ago by
Mike 700.
- September 7, 2022 at 6:45 pm#195882
Other half has a lithium powered travel scooter, mainly used for holidays. Not used since June, I topped the battery up a couple of months ago, came to top up again today and was surprised it took 3 hours to charge. It is a very large capacity (Li Tech Marathon) 26 mile range. Do lithium batteries self discharge, we have had the very warm weather in August if that affects it. Cheers.
- September 8, 2022 at 10:54 am #195901
The rate of self-discharge is also heavily dependent on temperature. The hotter a given battery is, the quicker it will self-discharge. Most lithium-ion batteries have a self-discharge rate of between 5 and 10% per month. This means that a fully charged battery will lose between 5 and 10% of its charge per month.
If you really wanna look at discharge rates of bateries more then checkout this link
https://batteryuniversity.com/article/bu-802b-what-does-elevated-self-discharge-do
September 8, 2022 at 11:35 am #195902Cheers rox that’s very helpful. I thought the high temperatures we had in July and August May have speeded up the discharge rate. The scooter is stored in the conservatory, I’m glad I took the battery out and left it under the stairs, it would’ve cooked.
September 9, 2022 at 4:07 pm #195953This thread got me a bit worried when I first read it because back in March I got myself an auto-folding scooter that came with Li-on batteries.
I have two batteries for the scooter used in a flip-flop way, one on, one off, after every use and as it used a few times a week its not a problem.
Where my problem is, if it is a problem, is my old scooter that I upgraded the batteries from lead acid to li-on and I haven’t used it since March.
Now I’ve always been lead to believe that Li-on batteries have a very slow discharge rate but should be stored after a full charge. So seeing this thread the other day I quickly got the old scooter batteries from out under the stairs and charged them up and they were fully charged within ten minutes so in 6 plus months they haven’t discharge much at all but thanks for a timely reminder guys. ?
September 11, 2022 at 9:27 am #196019I have a 2015 Pride Quest , bought second hand at 18 months old, in case of emergency & holidays , and it came with a sealed Lithium battery pack .
It has been unused, folded up in the garden shed for over 3 years , and last week I was putting the garden chair covers away, and had to move it.
So I put the key in and rode it out – still enough charge in it for 3-4 minutes use, after all that time.
Charged the battery for 4 hours or so, and it now shows it to be full – haven’t tried it since, and although I am confident it will be ok, I am now checking every week & charging if necessary, because ‘ have you seen the price of them ‘?
September 11, 2022 at 9:47 am #196023Mike, not sure I’d leave the battery pack in the shed, I may be mistaken and I’m happy to be corrected, but I’m not sure constant freezing temperatures in the winter are good for batteries. I keep ours under the stairs.
September 11, 2022 at 10:35 am #196024Mike, lithium batteries last longer if stored with 40-50% charge. Best not to keep topping it up like you would a lead acid battery. Only charge it when you want to use it.
September 11, 2022 at 11:19 am #196027Spare lithium batteries for computers were recommended kept in a fridge to slow down their normal deterioration, so unless it ever freezes in your shed, Mike, it seems like a good place!
September 11, 2022 at 3:45 pm #196038Thank you gentlemen,
I have taken the battery pack off the scooter and found a place to store it under the stairs.
September 11, 2022 at 6:38 pm #196042WW
thanks, it does get extremely cold as it is a metal shed.
what I have done over the summer is put some cover over it in that I bought some
artificial grass at a really knockdown price and covered the whole shed, except for the vents .
time will tell
