- This topic has 4 replies, 2 voices, and was last updated 5 years, 2 months ago by .
OK, so you rock up at an ultra-rapid charger, it says it can deliver upto 150kW and the car says it can use upto 100kW, so that’s easy, it’ll charge at 100kW right?
The charger & the car manufacturer are using ideal figures where all the conditions are met to get that fast charge rate, so no, it’s unlikely you’ll see that rate of charge for very long & only if many other conditions are right.
Chargers may limit the amount they can deliver at certain times of the day when electricity is super expensive (4-7pm). The BP Pulse ultra-rapids have a battery inside the adjoining cabinets that charges up when cars aren’t pulling too much so that they can discharge & privide a boost to the charging speed when needed. Late in the daytime these chargers batteries are getting depleted.
The EVs demand only a certain current from the chargers, this is the usual limitation that gets you less than the 100kW & it’s the car’s Battery Management System (BMS) that only wants so much so that it can heat up/cool down the battery, balance the battery at slower speeds & high states of charge.
Some cars “Rapidgate”, that means the battery gets too hot & the BMS limits the charging rate to stop the heat damaging the battery.
Some cars “Coldgate”, that means they don’t maintain enough temperature in the battery to charge optimally.
Then there are charge curves & profiles that every EV has, they all slow down as they reach a higher state of charge (the reason why BEV drivers only take 80% charge before heading for the next charger 100 miles on into their journey, it’s simply to spend less time charging overall).
We have coping strategies to deal with these problems, such as driving fast to the first 50kW rapid charger rather than an ultra-rapid as we know the battery is cold, charging there then heading to use ultra-rapids for the next legs of the journey & ride the 25C wave & the faster charging it allows. Another is to pulse the battery by speeding up & slowing down a few times (yo-yo-ing) before reaching a charger to increase the temperature, or driving more slowly if you want to decrease the temperature.
It’s early days for EVs & in time these problems will be solved by better battery technology, but until that time, the above hints could save you as much as 4 minutes at a charger, so sip your coffee & just charge as you want & wonder why some of us spend more than 4 minutes writing about it.
