Skoda Enyaq 85 SEL MY27
  • #385770
      Picked the Enyaq up 2 weeks ago, it is the base 85 model no extras apart from the factory retractable tow bar which I love.
      The MY27 comes with a front Frunk capable of storing all your leads including the granny lead , the Enyaq does not come standard with the granny lead, it is an expensive option, I brought new on eBay for £87.
      No spare wheel or jack just a trye sealant inflator, I brought a complete space saver kit online £199.
      ADSA 3.00 system still getting used to it, ACC very responsive, Travel assist will virtually self drive the vehicle by itself. Driver awerness monitoring system, if you remove both hands from the steering wheel whilst driving the Enyaq will stop. Excellent safety systems.
      Bosch battery managment system, battery now 79kWh as opposed to 77kWh, you can set your driving history mode setting we are now seeing between 3.6/3.9 miles kWh, today with the heating off 4.7 miles kWh.
      We are recording about 5% charging energy losses.
      • This topic was modified 4 days, 13 hours ago by Oscarmax.
      • This topic was modified 4 days, 11 hours ago by Oscarmax.
    • #385771
      72 dudes
        Those figures sound good Oscarmax.
        I rarely see more than 3.7 miles/kWh in my i4 except in the summer months where 4.5 is achievable on a longer run. And this works out at less than 2p per mile with Octopus IG.
        Looking forward to better figures, greater range and even lower running costs when the Enyaq arrives.
        #385774
          I am using Eco mode, setting the heating on local journeys 26 miles in total 22 degrees C 3.6, 20 degrees 3.7 and 18 degrees seats on 3.9kWh. heating off seats on 4.7kWh today. Not done a longish run yet.
          #385775
          belfast4
            A front Fruck need to be careful how you say that. Is it not a Frunk?
            #385778
              Or something in-between.
              #385784
                I thought it was a Frunk, given its a portmanteau of “front” and “trunk.”
                That said never heard of a fruck, other than in slang
                #385786
                shaan200
                  Its quite small, you can just about fit a charging cable in and it only support max weight of 8kg.
                  #385787
                    Charging and granny cable
                    #385792
                      All this Trunk/Frunk americanism’s nonsense! Its clearly a front compartment, yes, its a Fartment.
                      #385793
                        I’ve read to have heated seats on and steering wheel gives longer range than heating air con ?
                        #385794
                          Heating on 18 degrees C front seats on max local 34 mile journeys  3.6 miles kWh, outside temperature 8/10 degrees.
                          Yesterday tuned the heating off, heated seats on 4.7 Miles kWh, hopefully the new Bosch battery management is more efficient.
                          One pedal braking brings the vehicle quickly to a halt, I was using normal, now max, no need to use the brake pedal.
                          • This reply was modified 3 days, 13 hours ago by Oscarmax.
                          • This reply was modified 3 days, 9 hours ago by Oscarmax.
                          • This reply was modified 2 days, 9 hours ago by Oscarmax.
