revisiting options renault symbioz, cupra formentor ,nissan quashqai
  • #326002
    mitch
      here we are awake at 5am again lol. unable to sleep so trawling through the suv sized options and previous cars considered.
      the renault symbioz esprit alpine has reduced in price to 393 wpms. thats the middle option but gives you electric seats and tailgate heated seats and steering wheel so all the nice to haves and a decent mpg. the drawback was the door entry shape i want to recheck and see if i can find a comfortable wa in/out.
      the cupra formentor v2 has gone down to £343 and was a suprise comfortable sit test, v2 gives you all the nice to haves as well. its drawback is the 40mpg which given the plunge in my mileage isnt a deal breaker now as i cant see my mileage increasing unless you know jobs going for a 66 year old. i do like the styling i know its a bit marmite.
      the quashqai 1.5 e-power n-connector £347 wpms, ap has remained pretty steady the last couple of quarters it lacks some of the nice to haves heated stuff for winter.but is a nice place to sit.
      the mg zs and hs trophy are the bargain pricewise they have all the kit but there was just something about the cockpit that didnt click hopefully the test drives on the 24th will put that to bed.
      citroen c3 aircross max the ap went up to £627 so is above what i am comfortable with but the cockpit and test drive comfort keep it on my list along with the budget option of the c3.
      mini countryman electric monochrome remains on the list as the sit test was so good like putting on old slippers lol. just a question of can i get my head around the charging. and the 0ap is very tempting.
      i am going to go to chesterfield at 10.30 as most of these dealers are on the same street.
      ive booked mini and mg test drives so will do the same for the others and see if there are any deals  to be had.
      sensible head says one of the hybrids but the mini and the cupra were nice places to sit and are tempting.
      i may even risk waiting to see if the citroens come down next quarter, being very selfish i could order something this quarter and change next if prices come down although i am not too comfortable with that.
    Viewing 25 replies - 51 through 75 (of 315 total)
    • #330029
        Subtle
        Are you trying to say I’m putting a strong recommendation in? Never! 😂
        Mind you have drove the new ZS hybrid thingy, it isn’t half pokey with near 200bhp 400+ NM torque.
        Anyhow, I’m looking at the best of both worlds and I did try to make it less subtle going back to the mini😜
        #330030
          P (kW) = A x V / 1000
          10A granny charger 2.4kW + losses – over 20mtr would be 8A 2.16kW
          20kW over 10 hrs
          At standard variable rate, charging at home would half your costs!
          #330035
          mitch
            mmm could i get away with parking on the front lawn once a week overnight lol.
            tempting.
            trouble  maker.
            #330040
            mitch
              better to ask for forgiveness than permission lol.
              #330041
                mmm could i get away with parking on the front lawn once a week overnight lol. tempting. trouble maker.
                Why the council can’t run 2 rows of flags orver the dog shit area and up your lawn and allow use of kerb ramps is beyond me however if you can get away with it.
                Once you have done all your test drives (as you can see I want you to try the mg’s😂) I will get the information for you to give the council, if the mini electric is your choice.
                On another not didn’t someone say the Juke Tekna didn’t have heated steering wheek? worth checking spec’s incase it was the pre refresh model.
                #330042
                mitch
                  Technical SpecificationTechnical Specification Diameter of cables OD:11mm
                  Weight
                  5 metres = 2.4kg
                  7 metres = 2.7kg
                  10 metres = 2.7kg
                  15 metres = 4.2kg
                  20 metres = 5.1kg
                  25 metres = 5.8kg
                  30 metres = 6.7kg
                  Control Box dimensions 210L x 85W x 50Dmm
                  Charging rate 2.3kW
                  Delivers approximately 8-10 miles per hour of charge
                  IP Rating IP65
                  Protected against low pressure jets of water from all directions e.g a hosepipe. Fine to be left outside all year.
                  Connectors
                  Type 1 SAE J1772
                  Type 2 IEC 62196
                  UK plug rated for EV charging with temperature sensor complying to BS1363 – EV
                  Cable AC Single Phase
                  RCD Protection Type B – 6mA DC 30mAC
                  Charge Box Holder  Included (Installation optional)
                  Amp  10 Amp
                  Operating Temperature Window. -30C to +50C
                  Certification UKCA, CE
                  Warranty of products 12 months
                  ev extras £149.00 for 7 metres
                  backed up on my front would reach lounge wall socket.
                  going forward i would be happy to get a proper outside socket fitted.
                  • This reply was modified 6 months ago by mitch.
                  #330044
                    Is there a socket on the inside front wall of the house?
                    #330046
                    mitch
                      yes
                      #330049
                      mitch
                        the small window to the right of the drain pipe slightly to the right hand side of the window below the window sill inside is the main fuse box etc.about where you can see the fork handle.
                        #330758
                          mitch
                            brilliant thanks kezo.
                            i will sort a photo out that shows the distance to kerb.
                            but i reckon putting the car right outside the bungalow once a week overnight might be the solution.
                            better to ask for forgiveness than to ask for permission lol.
                            #330761
                            mitch
                              youu can see from this the distance we have to park from the bungalow.i would drive over the grass and park just in front of the wheely bins.
                              #330762
                                brilliant thanks kezo. i will sort a photo out that shows the distance to kerb. but i reckon putting the car right outside the bungalow once a week overnight might be the solution. better to ask for forgiveness than to ask for permission lol.
                                Yes lol, I agree!
                                I would still get a cable thats long enough to reach the road and potential for a cable cover for winter months and when its raining (muddy), which would amost certainly draw attention with 2 tyre tracks😂
                                A cable tide/holder on the wall would only cost around £10 and you could unwind how ever much is needed. Cheaper buying a long lead than buying a short lead only to realise you need a longer one.
                                The cable cover compllies with highways section 66 and supplied with necessary warning sign
                                Even with buying these, it would still save a good chunk over 3 yrs..
                                #330771
                                mitch
                                  i agree, i have put in a request for an outside socket either self funded or for them to install.rykneld are quite good and i think they may insist on their own sparks doing stuff. i think it would be relatively simple as all they would have to do is drill through one wall and lay cables less than a foot from the fusebox/meter through the wall and then as much cable as needed to locate. they could actually literally put it where they drill through.
                                  #330773
                                  mitch
                                    20 metres will give 1.5m leeway. £259.00 from a company in nottingham.
                                    so if i can get the outdoor socket suitabley specced its doable current tarrif until nov 26 22p/kwh.
                                    if i can get a split or overnight tarriff it could be cheaper.
                                    current supplier eon does a midnight to  6am at 7.5p.
                                    • This reply was modified 6 months ago by mitch. Reason: new tarriff figures
                                    #330786
                                    mitch
                                      ok i have pricedd up 20m cables and they arent as expensive as i thoght they would be.
                                      so i have sent 2 requests to the landlord to see if they will allow installation of an outside socket for granny charger and to see if they will allow a charger to be fitted. i realise i may have an issue with motability as they usually insist on offroad parking. either way a once a week overnight charge will work with my scheduled mileage.previously when i was persuing a driveway they did say they would allow the charger.
                                      going to try and bring forward the mg test drives tommorrow so at least ive tested all possibles.
                                      thanks again guys for the assist.
                                      #330787
                                        When motability fit the free charger how long is the cable ?
                                        #330788
                                        mitch
                                          these are the electrics just by the front door under the small window
                                          #330789
                                          mitch
                                            @menorcamike, looks like 5m or 8m as standard as part of the motability fit. i would need my own cable at my own cost as its so far to the road. will be interesting to see if they will allow me a free one or wether i will need to totally self fund. otherwise it will be granny charger.
                                            #330790
                                              Many thanks Mitch your bungalow looks lovely a lot like mine
                                              #330791
                                              Jason23
                                                When I had mine fitted I went with the 5m cable and found out later it was too short so I bought an extension cable off Amazon (10m) and it works now.
                                                #330801
                                                  ok i have pricedd up 20m cables and they arent as expensive as i thoght they would be. so i have sent 2 requests to the landlord to see if they will allow installation of an outside socket for granny charger and to see if they will allow a charger to be fitted. i realise i may have an issue with motability as they usually insist on offroad parking. either way a once a week overnight charge will work with my scheduled mileage.previously when i was persuing a driveway they did say they would allow the charger. going to try and bring forward the mg test drives tommorrow so at least ive tested all possibles. thanks again guys for the assist.
                                                  Its highly unlikely Ohme (Motability) will consider installng a charger, as they ereauire off road parking and confirm, as well as check and ask permission of the landlord.
                                                  Of caurse, there is the option of self funding a non tethered charger on the QT, but the costs will outweigh that of having a hybrid.
                                                  #330803
                                                  mitch
                                                    yep thats what i was thinking kezo so i wont build my hopes up on the charger, but even the outside socket and a granny charger once a week maybe a bit more often in winter or mixed in with the odd dobbies fast charge will still be cheaper than all dobbies.
                                                    they are usually pretty quick responding so i will probably know early next week which is feasable.
                                                    #330821
                                                      Odd question, I know, but what are the neighbours like?  The reason I raise the point is that we’ve a good few who would cheerfully complain to housing associations, landlords, council or anyone else just because they’re bored.  It seems a dark secret about the Cornish community spirit that takes such pride in looking after each other, some would also cheerfully  drop neighbours deep in the proverbial if they were to try something they disagreed with, even if it made no difference to their lives.
                                                      Id love it if you found a solution which genuinely saves you money but I’d also hate it if after a few months some arsehat decided to ruin it for you, especially if that then impacted on every aspect of life.
                                                        Very good point @MFillingham especially when planning on driving over community lawns!
