Patio Cleaning
  • #346118
      I have a Karcher pressure washer, my patio needs a clean. Is it worth investing in one of those rotating brush heads or is the jet enough, the patio stone is a year old so the dirt shouldn’t be to ground in.
      I’ve seen a cheap Screwfix own brand one for £20 anyone know if this will fit the Karcher.
    • #346586
        Less mess, but need to take your time, otherwise you can see where missed. Adaptors are available for cross compatibility with Karcher,
        Compatible patio heads can be found on ebay or used genuine for not much more.
        If not that dirty get some patio cleaner, use a stiff brush and hose off, much gentler on concrete pavers.
        • This reply was modified 3 months, 4 weeks ago by kezo.
        #346593
          Less mess, but need to take your time, otherwise you can see where missed. Adaptors are available for cross compatibility with Karcher, Compatible patio heads can be found on ebay or used genuine for not much more. If not that dirty get some patio cleaner, use a stiff brush and hose off, much gentler on concrete pavers.
          Cheers Kezo, I’ll look for one on eBay, don’t really want to use chemicals, I’ve got lots of plants.
          #346595
            Sprinkling of soda cystals with some fairy liquid. scrub with stiff brush, leave a couple hours and rinse. Also PH neutral (Unibos) and organic (Algon) cleaners won’t harm plants.
            #346600
              The scrubbing sounds a bit too much like hard work. 😂 I’ve seen a Karcher compatible cleaner for £14.
