- This topic has 15 replies, 10 voices, and was last updated 3 years, 9 months ago by
ChrisK.
- December 4, 2019 at 6:58 pm#98600
MaryI won’t bore you with the detail but basically my dealer has deliberately (IMHO) not returned my calls for days but finally when he did phone about my car he admitted that a door had been damaged in transit and a brand new door (not repair) is being put on.
Should I be concerned about the damage or is this a common problem dealers face with new car deliveries and sometimes they don’t tell customers?
Any advice is welcomed.
- December 4, 2019 at 7:39 pm #98605
JackIt’s more common than you think, although I highly doubt they will fit a whole new door.
December 4, 2019 at 7:51 pm #98606I used to work in a bodyshop and probably a quarter of the work through the place were brand-new cars damaged in transit. Depends on the amount of damage but I’m with Jack, it’s unlikely to be a complete new door – a door skin or a repair is more likely unless it was severely damaged in which case I’d be paying close attenti0n to the hinges and locking pins etc, basically anywhere the door physically attaches to the car when closed.
December 4, 2019 at 8:23 pm #98608
MaryThanks for the response. I was told that the damage to the rear sliding door was only a dent but because it is a brand new car and happened in transit VW are replacing the whole door under their manufacturers warranty and not the dealers warranty. I am sceptical of any excuse of damage and understand this sort of things happen often without the new owner even knowing. To set my mind at rest I will ask to see the order form sheet for a new door which they should have. The dealers have knocked £300 off AP as a goodwill gesture.
Should I let Motability know or do the dealers have to inform Motability of the damage?
Thanks
December 5, 2019 at 7:43 am #98636Mary, regardless of whether it is a new door or a re-skinned door, I would advise that, when you see the car, that you check and are completely happy with the colour match. If you have someone with you when viewing, then have them give opinion as well.
I would certainly not be overly concerned about the fact that is has happened, but the last thing you want is to suddenly notice a difference some time later. Also, please make sure that the repair is fully noted on the dealers notes as it will make it easier when dealing with any issues under warranty.
Good luck.? I will be remembered for nothing but had great fun doing it ?
December 5, 2019 at 4:12 pm #98692Sounds strange to replace a door for a dent, it could be the door has extensive damage and can’t be repaired but they don’t want you to know as you might refuse the car, I would ask for pictures of the damage before I even considered accepting the car as it could have all sorts of problems down the line, don’t let them fob you off as they would have had to take pictures to get the repair authorised and if they say you can’t look at them or haven’t got any then I would be asking for a report on the exact damage that has been done as you could end up with a lemon for 3 years.
December 6, 2019 at 1:50 pm #98791
OlpkUnless they have a car of the same colour in stock and doing a door swap from that.
I’d be seriously checking colour match etc
December 6, 2019 at 8:34 pm #98996There are two sides to this problem….one yourself in not wanting a damaged new car and two….Motability not to concerned as long as you sign for it and accept it and in 3 years time they can sell it at auction and make a profit .
At the end of the day if you are not happy with the repair then don’t sign for it …then it’s down to them to sort out a replacement , they will be hoping you are desperate to get you new car so you are mobile again and may push you into signing saying the old car has to go back if you have one .
As others have said it’s more common than you think getting anew car bodywork repairs , as long as the colour match is good then except it but also check it shuts correctly and the electric window works as does the central locking .
Good luck .
December 6, 2019 at 11:02 pm #99008
Just2FishWhen my Seat Alhambra was apparently crashed by the dealer prior to delivery I was told that Seat did not allow for damaged new cars to be sold and that it would be returned to Portugal, where they are made. As I didn’t get to see the car I had my suspicions that this may or may not be true, it may have been sold to someone by another branch undamaged, but anyway I was left waiting for another, which I knew, from already having one, was worth doing. I have now taken delivery and am delighted with it.
December 7, 2019 at 1:49 am #99023
PhiljbIf repaired correctly it should be fine, I would ask to inspect the repair thoroughly, paint colour match and finish.
Then test drive it so nothing else was damaged? It could have fallen off a transport truck or anything, listen for any rattling trim or wind noise around the door rubbers.
You’re still covered under warranty if anything goes wrong but do you need the hassle.July 30, 2022 at 10:35 am #192233I was waiting a fair timer for my car and now it is at the dealers pdi inspection found a problem i got a phone call from the sales manager that i now will not get the car till end August Sep time as there is a problem with Emissions and it needs a new part which will not be available till middle of August.To be honest i am quite shocked by this and i said they might as well reg for Sep reg which he said he can do, i have been thinking about this and emailed the said manager and the motablity salesman saying can you explain what part is needed and can you send me some pictures of the car he said he would but to further my Suspicions i have not been replied to.
July 30, 2022 at 12:04 pm #192250I used to work at a major manufacturers distribution centre and transit damage was quite common.
The standard for new cars (especially for private customers) was different from used vehicles even if the used car was only pre registered and had a few miles on the clock.
Basically any dent that could not be repaired using high build primer was classed as used and couldn’t be sold as new, it was a no no to use filler on a new vehicle so it wouldn’t surprise if a complete new door is fitted rather than using filler to repair the door or re-skinning it.
July 30, 2022 at 1:23 pm #192259As many have said, it’s more common than you’d think and when you think about it not at all surprising that damage happens pre delivery.
Colour match would be my biggest concern, just check it well before accepting it.
As long as it looks right and works right I wouldn’t lose any sleep over it.
Skoda Karoq SEL.
July 30, 2022 at 2:13 pm #192272I was waiting a fair timer for my car and now it is at the dealers pdi inspection found a problem i got a phone call from the sales manager that i now will not get the car till end August Sep time as there is a problem with Emissions and it needs a new part which will not be available till middle of August.To be honest i am quite shocked by this and i said they might as well reg for Sep reg which he said he can do, i have been thinking about this and emailed the said manager and the motablity salesman saying can you explain what part is needed and can you send me some pictures of the car he said he would but to further my Suspicions i have not been replied to. .
They having a bubble or what?
July 30, 2022 at 2:33 pm #192274Hi Rox i have phoned them today and tell me they have to contact the factory for a software update so i am not sure about the sales manager telling me on weds it needs a new part Salesman today tells me they can send me a picture of the car as it still has paint protector on bonnet so i said i still want to see it.
July 30, 2022 at 3:17 pm #192277Asking them for the VIN number preferably a photo of it and that will put a Cat amongst the Pigeons if there telling porkies.
