Live in Scotland? No mains gas supply?
  • #268946
      While looking at grants for an air source heat pump I found grants available for a niche situation.
      If you have no mains gas supply and earn less than £31,000 a year and own your house you can receive free air source heat pump (including radiators and piping), solar panels and internal wall insulation.
      As I say “niche” as there won’t be many who don’t have mains gas but you never know.
      I don’t know if it’s available in other parts of the U.K.
    • #268947
        Surely there’s not much mains gas outside of the major conurbations? We smelt gas whilst on holiday in Cornwall and mentioned it to someone, they said it can’t be a gas leak as there’s no mains gas, everyone has oil or gas tanks and that was a reasonably built up area.
        #268948
          Well maybe more than I thought.
          Its over £30,000 worth of goodies.
          #268949
            Probably means the vast amount of home owning pensioners can benefit.
            #268953
              It’s a fantastic deal Jojoe and hopefully some here on the forum can benefit ?
              #269032
              blackj
                Problem with air source pump is if you do not live in a modern house with up-to-date insulation you need radiators the size of a football pitch to get any heat from them.
                #269060
                  @blackj what I did over the winter was turn my radiator temp down at the boiler to 45*C. If you can run your boiler at between 40 and 50*C during the winter your house will be fine, just as it is, for an air source heat pump.
                  I know you love the SNP government ? but if your insulation is not up to scratch they will help with the cost of that too.
                  #269061
                  blackj
                    The snp doesn’t help you it’s money they get from uk government to assist people in Scotland with heating.
                    #269156
                      Yup, we have gas, but we have just had cavity wall insulation done and awaiting loft insulation. Awaiting because we have asbestos in the loft and ‘they’ are removing it prior to the insulation being done! Very happy with that being FOC.
                      VW ID3 Max is my DD
                      #269164
                        Great news, I take it your boiler is less than 15 years old or you would have had that replaced as well?
                        #269859
                        ScotT
                        Spectator
                          What nonsense is this?
                          #269881
                            They have already replaced my gas system in its entirety around 5 years ago!
                            They are coming out this morning to survey the asbestos in the loft with a view to remove it before installing loft insulation.
                            VW ID3 Max is my DD
                            #269916
                              DumfriesDik that’s a huge saving as removing asbestos is expensive. Is there any other grants available to you as your as well getting everything done at once.
                              #270104
                                I think I have had most things now. I wish solar and batteries would be included!
                                VW ID3 Max is my DD
