Has anyone got a q100r (or similar sized chair) into the Enyaq post Jan 2025
  • #384749
    shaan200
      Hi everyone,
      Doing my own research i am slightly concerned. I am getting the Apex assist 150 installed into the enyaq but I am worried about the clearance. I was wondering if anyone has this hoist and /or the chair and the car?
    • #384752
        Mrs Joe has the Q50R and the Enyaq, don’t know the size difference between the 50 and 100 but here’s a photo of the Q50 in the Enyaq boot.
        #384754
        shaan200
          I appreciate that but sadly this is the q100r, mines also bigger as it has rhe kerb climber its also a rigid powerchair so only back rest folds down
          #384755
            Can’t see why it won’t fit (1010 x 540mm), but you’d need 100kg hoist.
            @shaan200
            has a bigger chair.
            #384756
            shaan200
              I am getting the 150kg hoist as my chair weighs more with the kerb climber etc so its around 103kg even with arm rest etc removed and the height of mine works out at 640mm. Thats mainly concern as the enyaq vertical opening is only 727mm and the hoist arm itself takes some height. Even Jeff Gosling the one that made it, the height wasnt sure about it (despite them knowing about me getting this car for the past 7 months), they weren’t confident it would work but it would be up to the adaptations specialist. I am more concerned on the day of them installing the adaptations the adaptations specialist turns round and says its not viable.
              • This reply was modified 1 month ago by shaan200.
              #384758
                If you ring Jeff Gosling in Bredbury 0161 430 2151 they will tell you which chairs fit in which cars, they have a database. When we were getting the Enyaq we considered a hoist and rang them, they asked which car and which chair and confirmed it would fit and recommended a hoist, we decided against the hoist in the end.
                #384761
                shaan200
                  I did thats why i am concerned ive been gettign mixed information with at times them saying it wont work, but then others saying it should work  ill likely call on Monday just to confirm itll all work once they start fitting my car, ill be devastated if they say it cant after all this time even when they said it would to be begin with.
                  #384762
                    You walk away and start again unfortunately.
                    #384764
                    shaan200
                      It would leave me pretty stuck, the only option id really have is a smaller car and rely on my manual wheelchair though this will create proble.s, and I’d just have ro get taxis places when I need my electric wheelchair. There arent really any other cars that suit my needs otherwise.
                      #384765
                        Kia PV5 for example
                        #384766
                        shaan200
                          The KIA PV5 is too tall and would be a struggle to fit it on the driveway to charge it sadly. But we’ll see ill update people here if it turns out not being feasible.
                          #384781
                          kdwolf
                            My personal experience with Jeff Gosling is limited to various types of left foot accelerators, but every time I called, they either knew 100% or would check and come back with 100% correct answer – never had any issue with them.
                            Motability Skoda Enyaq SportLine 85x April 2024 - September 2026 (won my case with Ombudsman)
                            Motability Mazda CX-60 PHEV July 2023 (early termination on mechanical grounds)
                            Motability VW Touran Family Pack May 2019
                            #385016
                            SerenityNow
                              My adaptations installer had me send the details of the car model and the dimensions of my chair folded (it’s similar to the q100, a dhcare esprit action). They confirmed the dimensions available after the hoist is fitted and that my chair will fit. I am going with a Kuga hybrid but will have to park against the fence due to narrow drive. Unfortunately there were no smaller vehicles I could find that fit chair + hoist. I wish Motability search gave boot opening height and width, not just depth and number of suitcases.
