Good Condition Bonus
  • #76284
    Joe
      Hi guys, currently on my 4th Motability vehicle about to receive my 5th.
      I’ve always received the good condition bonus but the other day whilst having a bit of a clearout I managed to spill some hite paint on the passenger seat. Nopthing is getting it off, including white spirit.
      Would I still get the good condition bonus?
    • #76285
      Trev
        Depends how noticeable it is i guess, is it water or oil based paint? Any chance of showing us a photo?
        #76286
        Avatar photoWardyGTC
          I wouldn’t expect to receive it under the circumstances, how much paint?
          Might be worth taking to a good valeter who might know how best to remove it, a small price to pay to be sure of your £500.
          Skoda Karoq SEL.
          #76288
          JS
            Try scrapping it first with a light wire brush or if you don’t have one use a fork and slightly agitate the paint off, then moisten with warm soapy water add baking soda if you have some and scrub with a scouring pad, clean off and repeat process, if it ends up looking worn or slightly discoloured then you should be fine under wear and tear, the key thing is to make it look like it could of been done through use rather than actual paint.
            Good luck.
            #76289
            James
              Hairspray or if your brave enough nail polish remover and warm soapy water
              keep is all updated and the best of luck
              #76291
              Joe
                #76292
                Carmad
                  Don’t think that will pass unfortunately.  Best bet as has been said is to try a professional valeter.  Good luck anyway.
                  #76293
                    Spray with WD40 leave to soak 5 mins then hard rub with hot damp cloth
                    #76295
                    James
                      I don’t think it will be too hard to get it, or at least enough for it to not be overly noticeable.
                      if your not confident a decent valeter will do it.
                      #76308
                      Philjb
                        Have you tried paint wipes. Available at all good diy stores or try some panel wipe or warm soapy water and then give the whole seat a shampoo.
                        If white spirit doesn’t soften it it’s not oil based. But you need to get it off as quick as possible.
                        you should get at least some of it off.
                        #76313
                        Anonymous
                          Steam cleaner with a microfiber cloth will take it off.
                          Just be gentle and take your time for best results.
                          #76319
                          paulhelliwell
                            Steam was the only way I managed it on my old car regardless of base
                            #76334
                            wonky
                              Hi,  In my experience, white spirit can’t shift dried oil based paint. Only cellulose thinners can help, this is what car sprayers used to thin their paint and clean their equipment. I’m talking of course before everything went water based. You can still get it.
                              Regards, wonky
