Fuel stations
  • #345057
      Morning bit of a heads up if people don’t get out so much these days…
      Fuel stations near me have signs saying no diesel, then only two petrol pumps open at a local Tesco.
      Just paid for 45.82 litres at £140.9 per l resulting in payment of £64.56..
      So if low on fuel, might be worth considering the situation if appointments etc are coming up soon..
    Viewing 25 replies - 1 through 25 (of 54 total)
    • #345059
        As with the last time that this happened, there would have been no problem until false rumours start spreading that there’s a shortage, which causes people to panic buy, which then causes a shortage that would never have happened had the rumours not started 🤔🙄
        #345061
          Well yes glos guy could be right there, however the signs are up at Tesco..
          For me when fuel is needed I just brim it usually when the warnings illuminate or sound on the vehicle..
          So if there’s any like me this morning and don’t take much notice, as mentioned it’s just a heads up as what’s going on locally to me..
          #345703
            Don’t forget to load up on toilet paper too because all the paper we use comes through the Straights of Hormuz because that’s where all the forest are.
            #345708
              Well I would’ve but the queues through the car park were to long at Tesco, leading to the petrol station 😆, so gave that a miss.
              No real change for me @Chris t as mentioned fill up to the max when needed..Just more expensive and noticed the signs..
              #345710
              Woodpecker
                If the Press get a hold of it from social media, it will go viral very quickly.
                It could be the Tesco manager who miscalculated, or they had a sudden run on Diesel…lol
                #345712
                  So your the one that spills diesel all over the road, because you over filled. 👁️👁️
                  #345715
                    Well time will tell I guess @Woodpecker should all be fine..
                    Things can escalate quickly, as Glos guy mentioned panic buying..
                    #345716
                      I’d be amazed if it were me Joss, as I don’t use the stuff thankfully, however would’ve been out of luck if I did, wouldn’t have I 💦
                      #345720
                        Ahh Okay so your electric then. Confused with your comment ajn
                        Well yes glos guy could be right there, however the signs are up at Tesco.. For me when fuel is needed I just brim it usually when the warnings illuminate or sound on the vehicle.. So if there’s any like me this morning and don’t take much notice, as mentioned it’s just a heads up as what’s going on locally to me..
                        #345721
                          Hybrid type vehicle Joss..
                          #345724
                            Just filled up at Tesco. No shortages and no queues. In and out with a full tank in 5 minutes as usual.
                            #345728
                              Same for my Daughter GlossGuy, so Woodpecker could be right here…
                              Maybe this can go Joss
                              #345734
                                I’ve seen Asda and Morrisons near me both be out of diesel at the same time a few times over the years, nothing to do with shortages they just ran out before the next delivery. I was once filling up with unleaded when the pump ran dry. These things just happen.
                                Enyaq EV
                                #345736
                                72 dudes
                                  That can’t happen Jojoe. Petrol stations shut off their tanks at a predetermined level, usually 3500 litres. With diesel it’s a little lower, maybe 2500 litres if there’s a national shortage.
                                  More likely the pump you were using was faulty and cut out.
                                  Speaking from experience as I work in a Sainsbury’s petrol station.
                                  Can you imagine the problems if all that sediment was to be pumped into customers’ tanks?
                                  Tanks get cleaned of any sediment every 6 months.
                                  #345737
                                    That can’t happen Jojoe. Petrol stations shut off their tanks at a predetermined level, usually 3500 litres. With diesel it’s a little lower, maybe 2500 litres if there’s a national shortage. More likely the pump you were using was faulty and cut out. Speaking from experience as I work in a Sainsbury’s petrol station. Can you imagine the problems if all that sediment was to be pumped into customers’ tanks? Tanks get cleaned of any sediment every 6 months.
                                    Definitely happened, it was my first car in the late 1980’s. I’m convinced it ran out as it started spluttering. Maybe they didn’t cut the pumps off in the 1980’s.
                                    Enyaq EV
                                    #345739
                                      Filled car along with 20l jerry can just before prices increased and although my local journeys are battery electric, the Tucson, just can’t help itself having the engine running at high idle, using quarter of a tank for no particular reason.
                                      #346590
                                        I filled up last night, cost me £3.65! (52kW) it didn’t last long, I did a 130 mile round trip at 6:30 this morning as I had a 25m briefing at Otterburn Range at 8am.
                                        Back home and car back on charge again!.  Octopus have already given me about 30% throughout the afternoon (must be a surplus of electrons somewhere) so it’s already up to 78% 🙂
                                        #346594
                                          Phaedra, I’m guessing those figures are impressive, because personally I don’t understand it, must admit though its ignorance on my part..
                                          What vehicle are you using..
                                          #346607
                                          Avatar photoDougieB
                                            So this is the quandary I now face.
                                            I have an MG hybrid+ on order for delivery at the end of this month. Are these rising fuel prices the incentive I need to cancel my order and make the leap to fully EV?
                                            Current car: Mini Countryman EV in very shiny black!
                                            Previous car: MG HS Exclusive in nice shiny black.
                                            #346608
                                              Morning Doug, for me I’m loving the MG, the saving on fuel from the Volvo (heavy right foot though admittedly) even the Wife has noticed.
                                              When looking at the Mg, size, space and AP were a positive.
                                              I have no idea the pricing of ev’s, installation for cables etc..
                                              Not sure if price comes into it for you, but if I need to hand this car back for any reason then I’m not going short of the out lay of money either..
                                              • This reply was modified 2 months ago by ajn. Reason: Spelling
                                              #346612
                                              Avatar photoDougieB
                                                Morning Doug, for me I’m loving the MG, the saving on fuel from the Volvo (heavy right foot though admittedly) even the Wife has noticed. When looking at the Mg, size, space and AP were a positive. I have no idea the pricing of ev’s, installation for cables etc.. Not sure if price comes into it for you, but if I need to hand this car back for any reason then I’m not going short of money either..
                                                I hear you.
                                                #346621
                                                  So this is the quandary I now face. I have an MG hybrid+ on order for delivery at the end of this month. Are these rising fuel prices the incentive I need to cancel my order and make the leap to fully EV?
                                                  Personally, I wouldn’t base a decision on car choice on the current situation, which could well be over before you even take delivery of the car! Even if it drags on for some months, which is likely I would think, it will still be a short term issue in the scheme of things. Diesel has gone up the most, but petrol hasn’t gone up as much (in percentage terms) as I thought it might, although I suspect that it will go up more before it starts to come down again. With Trump facing mid term elections later this year, and cost of living being a major issue (especially in the U.S. where they all drive around in gas guzzlers), steps will be taken to calm things, especially oil prices, before too long. Besides, gas and electric prices are on the up as well, although if low running costs are your priority when choosing a car, and you can charge at home (essential) and the range isn’t t an issue for you, an EV will always work out cheapest.
                                                  If an EV suits you they make a lot of sense through Motability, as all the usual worries of buying an EV privately (high up front costs, crippling depreciation, high insurance costs, greater tyre wear, risk of battery damage in a crash, cost of a home charger etc etc) are completely removed. There’s also a half decent choice of them through the scheme, unlike ICE cars. I’d base your decision on your annual usage and ability to charge, rather than current fuel prices.
                                                  #347964
                                                    @ ajn  Sorry, it’s an EV!!
                                                    Charged to 100% last night, 41kWh for £2.88.  The guess-o-meter currently showing 272 miles range, best I’ve had for a few months with the cr@ppy weather!.
                                                    Looks like prices will half in April, Octopus IntelligentGo customers are getting emails saying the off-peak rate is dropping from 7p to 3.49p.  Not had mine yet but we will see.
                                                    #347974
                                                      Thanks @phaedra
                                                      #348501
                                                        Well as mentioned above by other members, ( @Woodpecker ) fuel stations seem to be fine for refuelling, no shortages..
                                                        @DougieB
                                                        are you staying with MG ..
                                                        • This reply was modified 1 month, 3 weeks ago by ajn. Reason: Spelling
