Cupra Tavascan – AC
  • #373396
    joesto
      Hi all, had my Tavascan exactly 5 months today and the Air Con is blowing out hot air.
      Just been told by my garage that first ting is to ReGas it and I will have to pay for this – £149.99
      Plus, they can’t book me in until 9th October!!!
      Can I go anywhere for the re-gas? Has anyone else had to re-gas so soon after owning?
    • #373397
      jamie1c
        If you’re going to pay for it yourself I’d take it to kwik fit and have them check it.
        #373398
        joesto
          I can’t because it has a heat pump with R744
          #373399
          jamie1c
            That’s unfortunate, I hope you get it sorted sooner rather than later.
            #373400
              Hi all, had my Tavascan exactly 5 months today and the Air Con is blowing out hot air. Just been told by my garage that first ting is to ReGas it and I will have to pay for this – £149.99 Plus, they can’t book me in until 9th October!!! Can I go anywhere for the re-gas? Has anyone else had to re-gas so soon after owning?
              Surely that is covered under the warranty, I would contact Mobility.
              #373404
              Woodpecker
                @joesto
                Your car has a serious fault, with temps at 30deg + it is unusable.
                Contact motability and get them to do something. The car is not fit for purpose and the cooling system is faulty.
                You could take the car to another garage. But I would certainly be on the phone to motability to do something right away.
                That is ridiculous.
                If it needs a regas after 5 months, it is faulty.
                #373405
                  R744 is Co2 which is one of the less common types, hence why KrapFit don’t do.
                  Given you have only had the car 5 months I’d certainly be pushing Motability to deal with it at any VW group dealership.
                  Have you got recirculate button turned on.
                  #373588
                  Callum46
                    At 5 months, that is a warranty issue without question.
                    #373638
                      I agree with others that at 5 months old it’s a fault and should be covered under warranty. If it were me I would refuse to pay and insist that the main dealer rectifies it under the manufacturer’s warranty. If they refuse pass the problem on to Motability.
                      #373797
                      Dottie85
                        I’ve had my Tavascan around 16 months and the air con is fine and has never needed anything replacing.
                        Definitely a fault and a warranty issue.
                        #373830
                        joesto
                          So after posting yesterday, I called another Seat dealer (Southend) and was treated much better and initially given an appointment for next Monday. Unfortunately, they called this morning to cancel as they also are unable to work on the heat pump R744 gas.
                          Called Motability, explained the situation, left it with Customer services and waited for a call back.
                          Motability called back with the advice that she’d spoken to my dealer (Bromley) and the advice was that I email the branch manager to explain, as they might pull strings and get me in sooner – I’m not holding my breath.
                          Lost as to what I do next, the car is essentially useless, especially in current weather.
                          #373837
                            So after posting yesterday, I called another Seat dealer (Southend) and was treated much better and initially given an appointment for next Monday. Unfortunately, they called this morning to cancel as they also are unable to work on the heat pump R744 gas. Called Motability, explained the situation, left it with Customer services and waited for a call back. Motability called back with the advice that she’d spoken to my dealer (Bromley) and the advice was that I email the branch manager to explain, as they might pull strings and get me in sooner – I’m not holding my breath. Lost as to what I do next, the car is essentially useless, especially in current weather.
                            Unfortunately this is going down the rabbit hole.
                            Does your car have an heatpump, as Southend dealership have mentioned as I don’t believe they are standard fit on the Taviscan and would have been a factory option at time of order?
                            Its wrong of Motability customer services to put this back on you, telling you to deal with it, especially when its Motability’s car.
                            Its also concerning brand dealerships, suggesting they can’t work on the heatpump system to even do a quick recovery, vacuum and refill of refrigerant!
                            I think its one of those cases to get Motability’s ceo department involved, at least you will get a course of action with 24hrs on how its going to be sorted!
                            #373839
                            joesto
                              Any idea on how to contact that department?
                              Thanks
                              #373842
                                Any idea on how to contact that department? Thanks
                                andrewmiller@motabilityoperations.co.uk
                                Explain everthing thats happened and don’t forget to include your details inc phone number & car registration.
                                #373853
                                joesto
                                  Thanks Kezo. Email sent and had a response already.
                                  the tavascan did have a heat pump as standard in MY 25 v1 with winter pack.
                                  #373855
                                    Thanks Kezo. Email sent and had a response already. the tavascan did have a heat pump as standard in MY 25 v1 with winter pack.
                                    Great news!
                                    Are they going to sort it ?
                                    #373856
                                    joesto
                                      Just heard back from a senior customer services rep, she’s going to try to advance it by reaching back out to the dealer, but like I said earlier, I’m not holding out a great deal of hope on pace.
                                      I know it could be seen as dramatic, but it’s roasting out there at the moment, we pay a small fortune for these cars these days and I expect air conditioning. I’ve told her that if there’s no resolution in sight, I’ll want a hire car.
                                      #373857
                                        Fingers crossed!
                                        Certainly not dramatic in this heat.
                                        Maybe a tempory hirer car might be solution to throw back, if they say the dealer can’t advance.
                                        #373874
                                        Woodpecker
                                          @joesto
                                          Excellent you done as suggested, no doubt there will be something done about the car in the near future..
                                          That dealership handled that very badly. That is one garage to avoid i the future.
                                          #373877
                                            I had a seat Ibiza just a year old courtesy car when my chr had body repair I thought the seat build quality was very poor I’d never have one
