Charger for EV – terraced house no drive
  • #185193 Reply
    Wazza
    I am considering going for a Hyundai Kona electric. I live in a mid terrace house with no drive. Car is parked on the road. Those who live in a similar property did you bother to get a charger fitted? If yes what did you do with regards to the cable going across the pavement? Did you get a cable ramp/protector? I feel my only option is to charge via supermarket etc chargers or maybe go for the hybrid version. I mainly do local driving.
    Thanks in advance for any advice given.
  • #185201 Reply
    Chris
    Hi,
    I’ve been in protracted conversations with Motability and my County Council regarding a similar question and, to cut a long story short, some councils are allowing a charging cable to be run over a pavement for charging purposes (check with your own Council), as long as a cable protector is used.
    Motability will, in theory, install a charger on this basis, as long as your property is suitable: Motability use a number of charger installers, some of which will not proceed with an installation regardless of being given the go ahead by the Council, however we found that Ohme would.
    I should say that we have been given the go ahead but can’t currently find a suitable EV on the scheme, so haven’t put the theory into practice; speak to Motability!
    #185225 Reply
    Xz130
    Just to add a small point of view, most councils (in Scotland anyway) will let you run a cable across a pavement if you have a cable protector that is wheelchair/pram friendly and a sign warning of the trip hazard.
    Current car
    2019 Hyundai Ioniq Premium in black
    New car 2022 Hyundai Kona premium in Jungle green.
    #185226 Reply
    Xz130
    Also, I’m getting my Kona premium in June and I’m intending to charge via public charges which somehow are mostly free.
    Current car
    #185233 Reply
    Belfast4
    Just use the street light same as I do.
    #185245 Reply
    Jeff Schofield
    If you only drive locally hence not many miles then using public chargers is very feasible. A lot of supermarkets have free 7kw chargers or just top up to about 80% via a rapid one, more expensive but still cheaper than fossil fuels.
    #185262 Reply
    Chris
    If you can get the home charger installed then it would (generally), be the cheaper and more practical option. I accept that some supermarkets offer free charging but it’s only useful if it’s readily available and fits with your lifestyle, but definitely worth consideration.
Reply To: Charger for EV – terraced house no drive
